WR 400..... backfiring, stalling
5 replies to this topic
  • bake
Posted July 12, 2004 - 06:49 PM
Tonight on the way down the mountain my bike started acting up, it's backfiring and stalling.
At the bottom I tried to open it up on flatter ground and it started accelerating nice then nothing, motor stalled wouldn't refire. Any ideas?
  • Guest_Guest_*
Posted July 12, 2004 - 07:14 PM
Dirt in the float bowl? Tight valves? Mine did that one time with a resticted main air jet (too much filter oil). :thumbsup: Good luck
  • V968231
Posted July 14, 2004 - 12:29 AM
  • KevB
Posted July 20, 2004 - 04:22 AM
I had the same problem on my 98 WR400 during a weekend of wet-weather riding... turned out to be lots of water and cr*p in the carb, especially in the Acc. pump bowl. Take some compressed air to your jets and it should be fine...
  • The_Missile
Posted July 26, 2004 - 01:15 AM
cr&p in the carb ???
check your fuel filter
check your breather hoses & reroute one of each assembly to the air box to avoid sucking crap into it from water etc.
  • TallBoysWRF
Posted July 26, 2004 - 06:14 AM
Try changing your spark plug :thumbsup: My 99 acts similarly to what you are describing when the plug gets fouled. I change my plug and all is well. Just my .02
