bad day - '01 426F engine seized
37 replies to this topic
  • Scott_F
Posted August 05, 2002 - 11:21 AM
#21
I wouldn't use water. :D
Try solvent, kerosene, diesel, gasoline*. When you are done, swish some oil around in there and dump it out.
*Don't use a lighter to look in the tank after you are done! :)
  • Wyatt
Posted August 05, 2002 - 11:31 AM
#22
I would use kerosene.
  • Hick
Posted August 05, 2002 - 11:48 AM
#23
Originally posted by Extreme Diesel:
I'll give it a try next time I have it apart. What parts do you replace? Just the plates, or what?
I believe you replace the first set of plates, one steel and one friction, with the first two "plates" (one actually acts as a spring) from an '01.
I have not done this, I put a Hinson on my '00 before the '01 came out and that helped a great deal, but my stock '01 clutch still works 100% better.
More than a few TTalk members have done this, I have heard that the new plates change the clutch throw, coincidentally (?) there is also an extra piece to the linkage in the '01s that the '00s don't have.
Part Numbers:
5JG-16321-00-00 is the first friction plate
5JG-16383-00-00 this is the spring thing
5JG-16384-00-00 called the seat plate, goes in first.
All three should total about forty bucks or less.
The "extra" clutch linkage piece is an 11/32 ball that goes between the end of the actuating rod and the hat-shaped doo-hickey that pushes on the pressure plate. Sorry, no PN for this, but some guys have done w/out this part and I don't know if it is necessary, but if it were me I'd go ahead and order it to see if this the way to go, it is only 95 cents on Parts Fish...
Hope this helps.
  • Hi_N_Mity
Posted August 06, 2002 - 03:51 PM
#24
may we all bow our heads and have a moment of silence for our beloved 426 thumpin motor..
you will be missed, but not forgottin :D :D :)
  • Extreme_Diesel
Posted August 06, 2002 - 04:17 PM
#25
Thanks Hick!
  • Wyatt
Posted August 07, 2002 - 11:51 AM
#26
Steve, don't leave us hanging. Tell us what is going on with your bike.
  • skthom2320
Posted August 07, 2002 - 02:46 PM
#27
Sorry!
After discussing the finances with my wife I've decided that I have to do the work myself. At least most of it. I apologetically called the shop yesterday and told them. They said "no problem." I don't return to Houston until next week so I can't tear it down until then.
My wife said "Hey it's your hobby right? If you don't learn to do it now you never will." Sometimes women are logical at the wrong time.
I will repost after I tear things down.
Steve t
  • Wyatt
Posted August 07, 2002 - 04:47 PM
#28
Let me know if you need a hand. I have a crescent wrench, a new roll of duct tape, and an unopened pack of JB weld. I'm sure we could use all three!!
Seriously, if you need anything, give me a shout!
  • Eagle1
Posted August 07, 2002 - 08:35 PM
#29
Steve have fun tearing it down. It's actually not that bad (depending on what is broken, bent, scored) My buddy has a '00 WR 400, we were out on our first ride for the year and he punched a hole in the ignition cover. All the oil drained out. Not good. Even worse was that here in Washington there is so much mud that sometimes you can hardly see the motor. He didn't see the hole.... DOH!! Anyways he kept on riding and made it for another 2 mi. and the bike seized. We took the top end off removed the piston and cylinder, (both were badly scored and the rings were melted), and replaced cylinder, piston, rings, and ignition cover. I think he did it all for about $550. He got off easy. Hope the rebuild goes well, good luck.
  • mightybuck400
Posted August 07, 2002 - 08:39 PM
#30
One word "YAMALUBE"
  • skthom2320
Posted August 08, 2002 - 08:51 AM
#31
Eagle1 - thanks for the words of encouragment. I will tear into next week.
  • skthom2320
Posted August 08, 2002 - 01:00 PM
#32
I haven't forgotten about that 1/4" torque wrench of yours. :)
  • skthom2320
Posted August 13, 2002 - 12:45 PM
#33
Update for the TT brothers!
I had the shop tear apart my engine today. I bit the bullet and decided that I just was too inexperienced.
I was shocked to hear what it was.
The clip from the exhaust camshaft (from underneath the cam caps) was rolling around in the engine - NOT WHERE IT WAS SUPPOSED TO BE!
When I talked to the mechanic he asked if anyone had adjusted the valves lately. I said "No, why?" So he proceeded to explain what he found. Well, it turns out that I did have the camshafts off to see what size shims I had, but I have put 30 hours on the bike since then! I THOUGHT I was very careful getting those clips back in properly.
I guess not.
Anyway, I can't believe my luck. There was no damage to the engine. The clip got caught on the timing chain guide and tore a small piece of some rubber part. That's it.
As for the engine being locked up, the circlip must have gotten wedged between the chain guide and the chain when I stalled the bike in the corner. Then when I went to kickstart it, the clip wouldn't let the chain move. As for the oil not registering on the dipstick - as I rethink the events it was a good five minutes after the engine had been off before I checked it. Maybe more since I just sat and stared at the damn thing for a while thinking about what could be wrong.
Yikes!
I'm still counting my lucky stars. I just got off the phone with them and the bike is running great. I'm only out the labor/gaskets to take the engine apart and put it back together.
Hope this experience is useful to others. I do feel stupid though.
Steve T
[ August 13, 2002: Message edited by: skthom2320 ]
  • skthom2320
Posted August 13, 2002 - 12:46 PM
#34
oops - double post
  • Shawn_Mc
Posted August 13, 2002 - 01:59 PM
#35
Ya shoulda done it yourself. Then you would have the experience. Glad your not out a ton o cash though. Im wondering how many hammer heads out there would have kicked it hard enough to break that loose and fire the bike again?
  • Wyatt
Posted August 13, 2002 - 03:23 PM
#36
Great news!! :)
Now you can tell them to go ahead and have the external tanks added to your forks with all that money you saved!!! :D
I can't believe you rode for so long with that thaing floating around in there. Expect the worst and hope for the best. Isn't it a good feeling when something goes your way?
I just thought of something else. What would account for no oil showing on the stick? Were you just that low?
[ August 13, 2002: Message edited by: Wyatt ]
  • skthom2320
Posted August 13, 2002 - 03:59 PM
#37
I know, it was a long-winded post but I did answer that question too. :)
"As for the oil not registering on the dipstick - as I rethink the events it was a good five minutes after the engine had been off before I checked it. Maybe more since I just sat and stared at the damn thing for a while thinking about what could be wrong."
The sub-tanks are on next months budget! :D
Steve
  • Wyatt
Posted August 13, 2002 - 04:07 PM
#38
I guess I was so happy for you that I read right over that!
  • Hot  113 replies
  • On Yesterday, 06:20 PM
  • 0 replies
