wheres the pilot jet
5 replies to this topic
  • Mark_UK
Posted August 02, 2002 - 01:33 PM
ok,,,i have a 98 yz just reduced the squirt from 3 seconds to <.5 seconds
now it pops and bangs when i shut the throttle off.
i assume this is the result of the pilot jet being to weak?
ive turned the fuel screw out a full turn and it now sits at about 2 1/4 turns out.
so my question is
where on the carb will i find the pilot jet?
how much of a jump should i make in jet size.?
also should i raise the needle at all?
the bike runs hot at low revs [ again i assume this is a pilot jet issue?]
thanks in advance
  • Yak
Posted August 02, 2002 - 01:45 PM
On the bottom of the carb, undo that 17mm plug, its recessed in a hole about 3/4 inch up directly next to the main jet. The main jet is a 6mm hex, the pilot requires a skinny flat head screwdriver.
  • Boit
Posted August 02, 2002 - 07:17 PM
Yak; I think the 400's have a bottom plug that requires a 14mm wrench. Keihin wsied up on later years and put the 17mm plug for easier access.
  • Guest_mxrider426_*
Posted August 02, 2002 - 08:00 PM
Why did you make the ap squirt so little? When you change your jetting, you should only go one size at a time. All the symtoms you describe are from a lean pilot. I don't think you need to mess with the needle.
  • Shawn_Mc
Posted August 03, 2002 - 12:07 PM
Changing the pump squirt should not cause the condition you describe. While your correct in your diagnosis, Im betting you have a piece of something in the pilot jet, and just need to clean it out.
The pilot screw range is between 3/4 and 2 full turns out. If you cant get it right in that range, you should change out the pilot.
But I doubt that you should have to change it now. Unless you changed something else too.
  • Mark_UK
Posted August 03, 2002 - 08:58 PM
shawn
what throttle opening range does the pilot jet effect?
all i know is it was squirting a hell of a lot of neat fuel in for a long time, surely this kinda fuel flooding would mask any week jetting??
  • Hot  36 replies
  • Hot  28 replies
  • Hot  38 replies
  • Hot  47 replies
