Engine Performance but for how long
10 replies to this topic
  • thumpinTed
Posted July 10, 2004 - 04:43 AM
How long do these engines last when given at least a fair amount of maintence, oil changes at a proportional interval to riding style? I have a 00 WR400 and change the oil frequently: after 3 days of hard riding or 500 mi. I have not adjusted the valves yet because I have not noticed any loss of power or heard any valvetrain noises from the top end. I ride this bike pretty hard and have never experianced the woes people have talked about. Hot starts after a get off, jetting and carb adjustments,accell pump timing ect.Am I setting myself up for a catastrophic failure.I bought my bike at NCY and they put my pipe on and did the jetting and carb tweaks.Is it my good fortune and maintenence or should I tip my hat to NCY for giving me a bike thats dialed in. What would be a good compression test result be and how many kicks does it take? The cam timing is stock WR so does changing it to YZ bring along a bunch of headaches. I am considering the YZ timing but have read that people switch it back to WR or put after market cams in. Does anyone have a trouble free engine and what if anything did you do to keep it that way?
  • ncmountainman
Posted July 10, 2004 - 05:24 AM
what is this USFS license you speak of,is it good for entire U.S. or just CA?
  • thumpinTed
Posted July 10, 2004 - 06:20 AM
I have a hard plate so I can ride on any public road paved or primitive, but to ride forrest trails that is open to traffic you better have a forrest adventure pass $5.00 a day or 30 something a year(parking permit)even if you never stop for a minute.Now that the forrest burned up last year in So Cal I was turned away and was told I could not ride because of the fire danger and also I could not ride even with the hard plate.I also had a approved spark arrestor wich the ranger wanted to ticket me if I did not show the usfs stamp on the muffler skin. the ranger thought he knew the law, then a couple on a Harley chugged by W/ strait pipes and I said you better give them the same lecture you gave me.I told him I will be back when the forrest recovers.
  • Hamish
Posted July 10, 2004 - 12:23 PM
If I were you, I'd be doing my oil changes more often (300mi is recomended I believe). Never hurts to check the valve specs. Only takes a few hours to do, 95% of that time is removing and refitting all the parts that are in the way.
Can't advise on the compression test, I always use a leakdown tester.
  • r1superstar
Posted July 10, 2004 - 01:16 PM
Given the technology behind the new "Four Strokes" (which were adapted from Factory Raced Sportbikes), I'd say a very long time. I have approx. 3000 miles on my '02 WR426 and I ride the piss out of it. I have changed oil approx. every 300 miles, and checked the valve clearances three times. Each time they were in spec! I just recently did a top end (piston ring replacement).
The motor on these four stokes are strong ane reliable. :thumbsup:
  • SteadyEddy
Posted July 10, 2004 - 01:35 PM
whats a leakdown tester?
  • Hamish
Posted July 10, 2004 - 02:00 PM
a leakdown tester is a box that you connect to a compressor. It had a hose coming out of it that screws into the spark plug hole. The box has a pressure guage on it, marked in %. Basically it fills the cylinder with compressed air (engine on TDC. you need a friend to hold the crank in poisition with a socket otherwise the air will push the piston down, opening the valves) and measures the % of air pressure that leaks past the rings and valve seats. 10-15% is a good figure for a 4 stroke. Up to 30% is still usable. After that you have problems. If you remove the header pipe and air filter you can hear where the air is leaking from. Noise from exhaust or carb = valve seat problem. Noise from crankcase breather = rings/bore problem.
  • SteadyEddy
Posted July 10, 2004 - 02:06 PM
thats a great tool, makes much more sense then using a compression tester. But using both would give a good indication of the motor.
I have the compressor, so where can i get one and how much do you think one of these tools is worth?
  • Hamish
Posted July 10, 2004 - 03:44 PM
The unit I have access to is a snap-on brand, and therefore probably cost a shitload. Most bike/car mechanics will have one. Save yourself the $$$$ and just pay someone to do a leakdown on your engine if you are suspect. If you can get youyr hands on a leakdown tester, forget the compression tester.
  • SteadyEddy
Posted July 11, 2004 - 01:13 AM
Thanks for the info,
Hopefully I won't have to worry bout it just yet, ive only done 960km's on it.
:thumbsup:
  • DrtRidr51
Posted July 18, 2004 - 04:23 AM
Hey,
I was wondering how the 426 rides with the new piston and rings? Did u put a high compression piston in it?
thanks
