Exhaust leak question
3 replies to this topic
  • Siers55
Posted July 10, 2004 - 03:49 AM
I have a stock headpipe and a FMF stainless midpipe. I cannot seem to get a good seal where the two pipes connect. I have tried Ultimate Black silicone and 762 joint compound. The high heat just burns the stuff off. Also the vibreation creates cracks. Neither of these have produced a good seal. I have two questions:
1) Does anyone have a compound they would recommend to get a tight seal.
2) The leak is small. How much of a problem is this?
  • Jeffro426
Posted July 10, 2004 - 06:46 AM
On my Big gun exhaust it just used a slip on joint to connect the two and would results in quite the exhaust leak...i took the muffler section and cut three 1/2 inch long by 1/16 inch wide incisions around the diameter where it connects with the header and then clamped it to the headpipe using the stock exhaust clamp...worked great and no more leaks.
  • KILLERCUDA_83
Posted July 10, 2004 - 12:10 PM
Hey i was thinking about machining some exhaust flanges like cars have but smaller version and that way they just bolt up with a gasket in between and no leak at all but i would weld the header flange back a little bit from the end that way it still slide up in the muffler pipe side. Then after that it be a sure leak proof connection and easy to undo and put back all u have to do is buy a gasket every now and then. Or ur could just wrap it up like twice with header wrap?
  • Siers55
Posted July 11, 2004 - 05:23 PM
Is there a recommended sealant I can put on the connection. I want to avoid major alterations to the pipe.
SAS
:thumbsup:
  • Hot  28 replies
  • Hot  50 replies
  • Hot  36 replies
