Compression
6 replies to this topic
  • Guest_mxrider426_*
Posted August 01, 2002 - 07:25 AM
Does anyone know how much compression a 426 should get if you do a compression test?
  • therapture
Posted August 01, 2002 - 07:55 AM
1) push kickstarter to TDC
2) DO NOT pull compression release
3) stand on the kickstart lever.
4) if the lever won't go down within 2-3 secs, you have plenty of compression :)
J/K- I do not remember the actual numbers pal...the manual has it in there?
  • freestyle111
Posted August 01, 2002 - 10:07 AM
anything below 120lbs start thinking about rings
  • Shawn_Mc
Posted August 01, 2002 - 02:04 PM
On a test, Id be looking for about 180 psi. Your going to have to bump it (push start type) to get a read, because if ya pull the comp release...get the idea?
Get it rolling pretty good in 3rd or 4th, and remember the throttle should be wide open.
  • freestyle111
Posted August 01, 2002 - 05:29 PM
you can also use long 1\2" ratchet with 14mm socket just remove ignition cover plug and turn motor over wwith flywheel nut
Posted August 01, 2002 - 06:51 PM
I can't find a fitting for the comp tester that fits the plug hole. Anyone know where to get one?
  • freestyle111
Posted August 01, 2002 - 07:49 PM
instead of speading $150 on leakdown tester i made my own.you can make a compression tester same way.i busted out the ceramic inside of old spark plug then tapped inside plug [1\4"tap].i then bought a grease gun hose.1\8" fittings on ends.i also bought 2 1\8" to 1\4"couplers and attached spark plug on 1 end and compressor fitting on other.you would only need to use coupler for plug end compression test gauges have 1\8" inletPosted Image
[ August 01, 2002: Message edited by: freestyle111 ]
  • 0 replies
  • 10 replies
  • Hot  36 replies
  • Hot  113 replies
