WR426F Oil Filter Access
8 replies to this topic
  • redrider77
Posted July 04, 2004 - 11:40 AM
What is the trick to getting the last bolt on the oil filter cover out? Do you really have to take the (I have the stock) head pipe off? :thumbsup:
  • yasotay1
Posted July 04, 2004 - 01:38 PM
I have the exact bike and no you don't have to take the headpipe off. You should have plenty of room unless your headpipe is bent down. I have the stock headpipe as well on an 01 wr426.
  • icerider
Posted July 05, 2004 - 05:15 AM
I have change my oil at least 8 times now never had a problem with the pipe and it has all stock exhaust. Dont know why you have this problem :thumbsup:
Roost on!!
  • JVP
Posted July 05, 2004 - 11:57 AM
Most likely you head pipe is bent. My friend has the same problem with his WR426. It seems the WR426 a just a little less room to work than the WR450. :thumbsup:
  • redrider77
Posted July 05, 2004 - 12:42 PM
Yeah, it must be bent somehow. I looked at another 01426 today while I was riding, there was definatley no problem getting to the bolt on that bike. I guess I'll try loosing up the bolts on the head pipe and try and reposition it. Thanks for the input.
  • bushy
Posted July 05, 2004 - 02:56 PM
I belive the 02's have a higher headpipe for oil filter acess. 01's do not. :thumbsup:
  • Dodger
Posted July 06, 2004 - 05:46 AM
The '01's have a revamped bend to the head pipe, anything earlier have the lower bend. If you cannot access your upper right oil cover bolt, you bent your head pipe down a bit. I've too many to know this :thumbsup:....
Dodger :devil:
  • Dodger
The '01's have a revamped bend to the head pipe, anything earlier have the lower bend. If you cannot access your upper right oil cover bolt, you bent your head pipe down a bit. I've bent too many to know this :thumbsup:....
Dodger :devil:
  • Gadsen
Posted July 06, 2004 - 04:00 PM
I have a 01 WR426F with the stock exhaust and remove nothing to change the oil filter. :devil:
