Piston, when?
4 replies to this topic
  • mike_dean
Posted July 25, 2002 - 01:18 AM
When would you replace your piston as regular maintenance? '00 426, over 200 hrs, engine has never been apart, runs great. thanks mike
  • John_Lorenz
Posted July 25, 2002 - 04:32 AM
Intresting question
I was just going over the Maint Schedual per the Yami Manual.
If I remember from last night I think it said
every 3rd race or 500 or 1000k to inspect / replace if needed.
So this brings up agood point.
Who follows the recommended Maint schedual / chk as perscribed by the manual.
Opps dang fat finger hit return to quick
I would say if it aint broke dont fix it. If compression is well in the standard and no smoke is seen, then why ?
But then again, I am a tinkerer and plan on an engine tear down this Winter.
Why a engine tear down, Check trannie, clutch, oil pump, crank piston and valves to specification.
Who knows I may just bore it to a 440 :)
[ July 25, 2002: Message edited by: E.G.O.**** ]
  • Ga426owner
Posted July 25, 2002 - 04:42 AM
I just had my top end done on my 01 with about 150hrs. I noticed a decrease in power & that is why I did it.
  • Shawn_Mc
Posted July 25, 2002 - 09:33 PM
Pistons can get fatigued. If you have been racing it hard, you might want to do a piston. I doubt the bore would need work. Basically what Id call a "top end refresh". Id be more worried about the valve springs. They are much more likley to fail.
Its surprizing how much new valve springs will improve a motors manners. When I was racing super stock flatbottoms, we'd change the springs twice a season. And after the races we'd pull the push rods, so we wouldnt have one or two hangnig open, sacking out the spring. Just food for thought.
  • MikeOK
Posted July 25, 2002 - 01:54 PM
I rebuilt mine the first time at about 150 hours. It didn't need it. If I had it to do over again I would have waited until the compression didn't spec. One thing I found out is that the cylicer at 12.5:1 compression is much more critical than on a 2 stroke. If your new piston isn't just right you will have problems and have to either have it replated to match your piston, or go with the pricey stock piston. A good compromise would be to do a new set of rings if your compression is okay.
  • 10 replies
  • Hot  113 replies
  • Hot  47 replies
  • 0 replies
