frame filter
12 replies to this topic
  • ColoradoJim
Posted June 04, 2001 - 05:40 PM
I just attempted my first oil change .everything went fine until I tried to remove the frame filter nut It would not budge. It looks like it is not meant to come off, but the manual sure say it does. Do you have suggestions or advice.. Thanks
  • markerf
Posted June 04, 2001 - 06:52 PM
HEAT...Try applying heat to the female portion of the nut, not the male part this will also break away any paint that would be contibuting to you saying #^@!
  • 696
Posted June 04, 2001 - 08:53 PM
Just changed my friday. I used a big adjustable wrench and PULLED!! Just dont round off an edge, and when you put it on it doesn't have to be that tight.
696
2001 YR 426, YZ# Plate, YZ Fender, YZ pipe, YZ Tank, SDG YZ Seat, 13/50 Gearing, Pro-Taper Bars, TAG Triple Clamp, Moose Handguards, Maier Frameguards, Throttle Stop Trimmed, Air Box Lid Removed
  • Tim_in_WA
Posted June 05, 2001 - 01:53 AM
An impact wrench works great.
  • MN_Kevin
Posted June 05, 2001 - 02:11 AM
I would be hesitant to use heat in this application, considering the oil on the other side of the fitting. I understand the flash point of motor oil is higher than that of gasoline, but why push it. I spun mine off with a socket and 18" torque wrench.
I DO use heat to remove stuck nuts/bolts in many other applications. :)
'99 WZ/YR (you choose!) with ALL YZ mods, de-octopused, DSP Doug Henry airbox w/ velocity stack, FMF PowerBomb header, Stroker SX-1 silencer, SS front brake line, forked over by Pro-Action (and then fixed by me), OEM YZ tank, IMS YZ seat, carb mods by Jim Dean, Andy in OZ, & Sir "Taffy" from Jolly Old England, AMA, NESC, and I use MOBIL 1 Oil, with ZERO problems.
  • KerryT
Posted June 05, 2001 - 06:37 AM
I checked this screen after the first 50 miles and it was clean. After 2,500 miles or so I haven't looked at it. Should I check it out again? Has anyone found debris in the screen? Yes it is a bitch to get off!
  • MN_Kevin
Posted June 05, 2001 - 06:42 AM
Kerry, I did on my initial cleaning.
  • John_H
Posted June 05, 2001 - 07:03 AM
I use a socket and long torque wrench and comes right off. Was very tight the first time. Never have found any debris in that screen so I only check it now and then.
  • john_pearce
Posted June 05, 2001 - 08:14 AM
HI JIM
I USED A 24MM RING SPANNER , BUT GRANTED IT'S
REALLY TIGHT ( DONT USE HEAT ). DIDN'T FIND
ANY DEBRIS ON MY SCRREN AT ALL , SO I'LL
ONLY DO IT YEARLY . TO GET THE SCREEN OUT I FOUND IT NECESSARY TO REMOVE THE WHOLE OIL PIPE AND HOSE CONNECTED TO THE SCREEN (OTHERWISE THINGS GET A BIT TRICKY TRYING TO FLEX THE RUBBER HOSE ).
IF YOU CHOOSE TO DO THIS MAKE SURE YOU DON'T LOSE THE LOCATING DOWL AND THE O RING, WHERE
THE PIPE MEETS THE CASING.
HOPE THIS WILL HELP YOU OUT.
JOHN
HAMPSHIRE , ENGLAND
  • ColoradoJim
Posted June 06, 2001 - 02:27 AM
Talked with my dealer,he said after checking the screen several times there was never anything in there!! Also he said that after coming off a few times they will start to leak!!!!! SO DONT #*%# WITH IT!!! bETTER OFF LEFT ALONE I suppose.Over and out..
  • Guest_Guest_*
Posted June 06, 2001 - 02:40 AM
Checked my friends 99 wr 400 for the 1st time last month. Nothing! CLEAN>
  • z4me
Posted June 06, 2001 - 03:03 AM
That seems to be the consensus on the 250 side too. I checked mine a week ago and nothing. Clean even after I swamped the thing and the oil filter screen tore from the body due to mud clogging it. I don't think I will bother with it again.
- Sean
  • wrpunisher
Posted June 06, 2001 - 01:03 PM
I think I have more trouble pulling the oil hose off than getting the screen out. I looked at mine after break in, then just recently after ~1500 miles of offroad abuse, and never saw anything in there. I don't think I'll be messing with it again.
Chris
99WR400F
