will a header/pipe exhaust leak make an engine run very lean?
4 replies to this topic
  • Shane_Bettin
Posted July 01, 2004 - 01:39 PM
ive been having problems with my bike running really lean. theres is a leak where the header connects to the pipe, would that be the the problem. it was running perfect before but since i put as new pipe on its been real lean. i did go up a size with the main, 175-178. im thinkin of usen some kind of shrink wrap or somthin and maybe some gasket maker/sealant. any ideas?
  • Dolce_Grappa
Posted July 01, 2004 - 02:11 PM
Yes an exhaust leak will cause a lean condition; you can use Chamber Seal or Permatex, Ultra Black. Chamber Seal worked fine on the 2-smoke, but just melted from the exhaust temps from my 4-stroke.
NAPA will have the Ultra Black; you’ll have to let it cure a little prior to sliding on the silencer.
Let us know how it works for, ya!
  • Bobby_Holeshot
Posted July 02, 2004 - 06:57 AM
MXA Mag has a great article about how pipes work on MX bikes and talk about the importance of tight joints and leaks.
  • Shane_Bettin
Posted July 02, 2004 - 09:09 AM
does it talk about it on the web site, or which issue is it in?
  • sirthumpalot
Posted July 02, 2004 - 12:17 PM
You say it's lean, but where (at what throttle opening(s)) is it lean? For very small throttle openings (idle to about 1/4) play with the fuel screw and pilot jet. For mid openings (about 1/4-3/4) the needle and clip position will have a significant effect, and for over 3/4 the main jet will have the most effect. I'm not a jetting guru, but this is the basic way it works, hope this helps.
  • 0 replies
  • On January 15, 2017
