How do you get the front sprocket off??
7 replies to this topic
  • DoctorRzed
Posted July 23, 2002 - 09:00 PM
Is there any tips?
  • sirthumpalot
Posted July 23, 2002 - 09:05 PM
Where are you stuck? You have to flatten the washer and then loosen the bolt. If the bolt is stuck then put it in neutral and use an air impact wrench and it will come right off. Put it in neutral to isolate the tranny from the shock of the air gun, the counter shaft has plenty of mass [inertia] that the air gun will still work fine.
  • beengoneawhile
Posted July 23, 2002 - 11:48 AM
Flatten washer, leave chain on, step on rear brake, loosen nut with wrench/socket/etc....
  • PumpkinHumper
Posted July 23, 2002 - 02:11 PM
im with the chain/brake system. been doing it for years.
  • Fireball
Posted July 23, 2002 - 02:29 PM
Me too. Chain/Brake works just fine.
  • Vanilla_Gorilla
Posted July 23, 2002 - 04:18 PM
a real mechanic uses a 1/2 inch air impact wrench on this. the shock from the air impact gun wont hurt the trans but its not a bad idea to put the bike in neutral. its also helpful to keep the chain on untill the nut is off.
-alex
  • MotoGreg
Posted July 23, 2002 - 06:31 PM
I use a 1/2" impact gun but if you're not used to using one every day you may want to tighten it back up by hand with a torque wrench... an impact gun can easily twist the end of the shaft off if you're not used to using that gun.
  • John_Lorenz
Posted July 24, 2002 - 03:01 AM
I gotta do it
For those hard to remove items
I always use me trusted and proven Lil Buddie
http://www.zianet.co...plans/page4.htm
Of course use with caution :)
[ July 24, 2002: Message edited by: E.G.O.**** ]
  • On January 15, 2017
  • 5 replies
  • 0 replies
