1986 XR600 blowing blue smoke
2 replies to this topic
  • wsitch
Posted June 30, 2004 - 01:30 PM
Hi guys:
My new (to me) XR600 is blowing blue smoke on hard acceleration. It smoked a lot when started after a four-month sit in the previous owner's garage, but looked good afterwards. Too bad I didn't look behind me when test riding it. Oh well.
Friends say it definitely puffs a cloud of blue smoke when whacking the throttle for a wheelie, and they're pretty sure there's no smoke after a sharp rolloff of the throttle.
Does this sound like rings? Valves? Valve seats? Is there an easy way to tell?
I found JAW's guide to replacing rings:
http://jaw.iinet.net...nns/rering.html
It doesn't seem too oppressive.
Thoughts? Opinions?
Thanks!
  • smashinz2002
Posted June 30, 2004 - 05:51 PM
Yeah, that sounds like worn out rings to me. Worn valve guide oil seals will only smoke right after the bike is started, then it will stop. And it won't smoke when you hit the gas hard. However, if the rings are worn, it will smoke when you hit the gas, because you are increasing compression pressures and therefore blowing oil past the bad rings.
On an older air cooled bike, it's not too difficult to pull the cylinder and replace the rings. But you should for sure have the cylinder bored, and replace the piston with a matched up piston for the overbore. It's always a good idea to check/replace everything (do a complete top end job) any time you have it all apart.
After a new top end job is done, the bike MUST be broken in properly as if the engine is brand new.
My guess is that someone abused that engine and didnt keep the oil changed and/or didnt keep the air filter clean.
Good luck with it man, I know it's a lot of work to deal with, but it's worth it once it's rebuilt.
L.L. '00 XR650R street legal/ uncorked/jetted/ Fast Pig
'04 KX500 illegal/ crazy fast
Posted Image Posted Image
  • duke1110
Posted July 01, 2004 - 05:48 PM
my 86 did the same thing. i thought it was the valve seals till i took it apart. there was about 19 thousands between the piston and cylinder. smoked a little at idle and a lot when on the gas. so i would say go ahead and do the top end. i got my piston through here. best price i could find and great service!!! if you do your own wrenching it is very easy and economical. even with the wasted piston it had more power than i knew what to do with now i cant wait till it is fully broken in :thumbsup:
  • 3 replies
  • 22 replies
Honda XR650L 2016
  • 0 reviews
Fell Off Trailer by usafxr
  • Hot  43 replies
