XR650L jetting
10 replies to this topic
  • hubbapaul
Posted June 30, 2004 - 06:17 AM
I have a dyno-jet stage 1 jet kit and I drilled the slide holes to 5/32". Instead of shimming the needle can I just move it to the fourth position down? Isn't this the same thing as adding a shim?
  • uw153
Posted June 30, 2004 - 08:48 AM
Check my sig. The fourth position will be a little leaner, I think you'll be happier in the middle postion or third one down.
  • XR650L_Dave
Posted June 30, 2004 - 10:15 AM
Keihin jets and the stock needle shimmed work better than the dyno-jet kit.
The DJ kit is better than stock, but this way is better than the DJ kit.
I've run both ways.
  • hubbapaul
Posted July 02, 2004 - 07:40 PM
Thanks, the third one down has a lot less hesitation when I hit the throttle, thanks.
  • hubbapaul
Posted July 02, 2004 - 07:44 PM
Did you put the stock jet back in the carb or did you buy and install a keihn 165 jet. Does it make a big enough difference to buy and install the keihn stuff or is it a not that noticable improvment and where did you find a washer that was snug around the needle, radio shack didn't have any.
  • uw153
Posted July 03, 2004 - 02:52 AM
I used the Dynojet 165 that came with the kit. From what I have read the Kehin 158 is about the same as the Dynojet 165. There is some inconsistancies between manufacturers I suppose. XR_Dave is right though, I have read many reivews on the subject and just modifying the stock is the way to go but since you already have the Dynojet kit, I thought you might want to know which works best. I wouldn't use the 165 unless you do have an aftermarket pipe though. The stock will be too rich with the 165. :thumbsup:
  • POBLondon
Posted July 03, 2004 - 03:31 AM
This is my bike, as tested. I have ended up with pretty much a totally custom setup, but it works reqlly well. Even on Michelin Deserts with luggage I'm getting 22kpl economy and the power's great.
Click here for my latest XRL dynochart (number 5!)
  • MotoChris521
Posted July 04, 2004 - 02:25 AM
I used the Dynojet 165 that came with the kit. From what I have read the Kehin 158 is about the same as the Dynojet 165. There is some inconsistancies between manufacturers I suppose. XR_Dave is right though, I have read many reivews on the subject and just modifying the stock is the way to go but since you already have the Dynojet kit, I thought you might want to know which works best. I wouldn't use the 165 unless you do have an aftermarket pipe though. The stock will be too rich with the 165. :devil:
Hey uw, how do you like your "Q". I'd like to "quiet" my L down a bit(pro-circuit t-4).Is the power significantly more than stock ? :thumbsup:
  • uw153
Posted July 05, 2004 - 04:35 AM
I have the old 98db version of the Q and like it ok. It definately chokes it a bit witht the "quiet" insert in the end but without it it's as loud as the power core 4. I would like to try the new 96db version but the cost doesn't outweigh the sound right now. That being sade it is quiet enough not to anoy folks around me. I wish I new what db I really had. Mine is due for a repack though. Power increase over stock was better off idle response and more top end. But it was a bit louder too.
  • BrackneyC
Posted July 05, 2004 - 09:18 AM
Hey UW, this is the Rock Island connection. I am going to shoot for the re-jet this weekend. What does your schedule look like?
  • uw153
Posted July 09, 2004 - 02:09 AM
Hey there Brackney, did you get my PM.
