Rear rim 400/426 interchange
3 replies to this topic
  • flogger
Posted June 29, 2004 - 09:16 AM
I have a spare rear wheel for an 01 426 in the US. I have the 426 there. I have a 99 400 here in Mexico and have much more use for the wheel here if it will work. I hate to go to all the trouble to get it down here and it not fit. Do you guys know if it will change over?
Posted June 29, 2004 - 09:42 AM
The wheels are interchangeable, However the Brake rotors are NOT.... You must swap out the Rotor when changing out the wheel.
The 426 Rotor is about 1/2 inch wider in diameter.
Bonzai :thumbsup:
  • Matt96xr6
Posted June 29, 2004 - 03:18 PM
1/2" wider? &%$#@!? That disc is barely 1/4" thick to start with.
The 98-01 wheels will interchange. The 02 use a different hub and spokes for weight reduction. I believe the 00-01 supercede to the 02 hub now. Anyhow as long as you get the hub and spacers from the bike you should be fine.
For the rotor, the 98-01 rear is the same. The 02 is 5mm larger in diameter but runs fine on the earlier bikes with no other modifications.
  • flogger
Posted July 01, 2004 - 09:11 AM
Thanks for the info guys. I think when Yamkaze said wider he was refering to the diameter. But if the 5mm difference will still work then... Away we go!
