Grey wire mod?
11 replies to this topic
  • captain_S
Posted June 26, 2004 - 06:44 AM
Does this mod apply to all wr 426`s regardless of market destination?
  • Brettv
Posted June 26, 2004 - 02:55 PM
pretty sure, mines an aus model, and i had it on my 99
  • captain_S
Posted June 27, 2004 - 10:54 AM
Cheers!,was thinkin of givin it a try,and tryin the tps disconected :thumbsup:
  • Brettv
Posted June 27, 2004 - 01:38 PM
yeah ive put a switch on mine and mounted it on the bars, so that i can switch to yz or wr mapping easily. although if you do have it like that, you sholuld only switch when the bike is off. i think it can wreck the cdi a bit.
i was thinkin bout d/cthe tps too, let me know how you go.
:thumbsup:
  • toolie
Posted June 28, 2004 - 03:35 AM
Is the Canadian model the only wrs that came w/o the throttle stop, hence no grey mod required?
I would have thought Australian model would be the same as the Canadian....after all both countries got the RZee500 :thumbsup:
  • captain_S
Posted June 28, 2004 - 11:33 AM
Had a look at the grey wire and it was never connected from the factory!,it is there,just it has a blanking plug fitted to one end of the connector block,toolie is spot on,no throttle stop from the factory means the grey wire mod does not need to be done! :thumbsup:
  • bdeezy400
Posted June 28, 2004 - 01:35 PM
what exactly is the mod. i have a grey wire in a connector but not just a wire. if thats the wire do i just cut it or ground it out? the july Dirt Bike talked about it.2000 wr 400
  • Brettv
Posted June 28, 2004 - 03:33 PM
about the blanking plug, mine had that as well, just make sure that that connecter isnt joining both wires to ground.
  • captain_S
Posted June 29, 2004 - 11:14 AM
Thanks for that tip,i will take a closer look at the connector block? :thumbsup:bdeezy the mod changes cdi mapping from wr(grounded)yz(dissconected) :thumbsup:
  • bdeezy400
Posted June 29, 2004 - 02:38 PM
what kind of switch did you use? i picked up a little one from radio shack its rated at 6a @125vac , 3a @250vac, will that work?
  • Brettv
Posted June 29, 2004 - 04:47 PM
yeah that should work fine, i dont think the CDI would draw to much of a current, (not sure) but still that switch has a pretty high amp rating. i used a SPST for mine, (single pole, single throw) basically just a simple ON/OFF switch. just make sure you cover up all your soldering joining with tape or liquid electrical tape, to make sure its not shorting anywhere. :thumbsup:
  • captain_S
Posted June 30, 2004 - 10:59 AM
Had a look at the connector and they are not joined inside the plug,i even tested it with a multimeter to make sure!,so it was on yz mapping from new
