Light kit for an 02 YZ426
3 replies to this topic
  • JPEracing
Posted July 16, 2002 - 04:10 PM
Hi folks,
After a 10 year hiatus from dirt biking it`s time to come back home.
Anyway this is my first post and you folks have likely discussed this before.
What is the setup for adding a light kit to my YZ ? I`d like to make it "enduro" legal/plated for some of the Michigan trails.
Talked to Baja Design and they recommended swapping to a WR stator. Big Bucks...
How did you guys do it ???
  • JPEracing
Posted July 17, 2002 - 03:26 PM
YZman 400.
Thanks for the reply. I`d be interested in the setup you describe. Maybe we could talk more ? As there are still a few questions that I dont understand.
If you would, send me your email/phone number.
I live in New Baltimore, just up 94 between Detroit and Port Huron. Ride in the St.Helen area.
Thanks
  • MichaelRaasch260
Posted July 17, 2002 - 07:46 PM
You have some options. And it depends on how much you want to spend.
I have a E-line lighting coil that puts out 200watts with an Acerbis headlight kit that I got from E-Line. It came with a headlight (the 2 35 watt bulb kind), a wire harness, brake light switch, and a Acerbis tail/brake light. All for $650. It is the most powerful coil available. They have other light kits available but only the one coil. The coil alone costs $500.
I checked into buying WR parts but there were too many different part numbers that were different in the electrical system, so I couldn't tell what all needed to be replaced. It was going to cost probably $300 - $500.
You also can get your coil rewound from Electrics I think the name was. That coil puts out like 45watts and costs $90 maybe. Can't remember exactly. But I have the info somewhere.
If you want to know about any tricks that I needed to do just ask.
  • sirthumpalot
Posted July 18, 2002 - 01:02 AM
Did you have to add a larger cover on the left side to make room for the lighting coil? Also did it add any significant weight to the flywheel?
  • Hot  50 replies
  • Hot  36 replies
  • On January 15, 2017
  • 0 replies
