annihilating rear tires like crazy
16 replies to this topic
  • Rossco22
Posted June 25, 2004 - 10:41 AM
I have been running michelin rear tires now for the last 3 monthes. I normally run an m12 but the last time I ran an s12, big mistake. Im not sure why though, because I ride on soft terrain. the m12 holds up alright but the s12 peeled of in maybe 5 good rides. can anyone suggest a good tire for these monster yz450s? Thanks :thumbsup:
  • John_Lorenz
Posted June 25, 2004 - 11:00 AM
The unfortunate aspect of soft tires is they wear fast. 5 rides if you riding hard is about right. s12, 756 are about the same. I had used a MH2 that hardly even looked used. I just did not like it much so I went back to the Dunlop 756
  • DoctorRzed
Posted June 25, 2004 - 02:45 PM
Try the Kenda Millville :thumbsup:
I got 5 motos and 12 days of hill climbing out of it.
  • YZFan
Posted June 25, 2004 - 03:00 PM
I have a Kenda and really like it. I hve had it for a while and it is just now starting to chunk off lugs. I will get another Kenda if I get the chance.
  • RogerDedrick
Posted June 25, 2004 - 03:30 PM
If you like the Michelin try the starcross it has held up as long as the m12' for me and has a larger footprint as well
Roger
  • id250f
Posted June 27, 2004 - 05:51 AM
Kenda Unadilla lasted forever ... i only changed it because it just didn't feel right running the same tire for so long :thumbsup:. Dunlop 756 wears in 4 or 5 "good" track rides. I probably had a good 10 - 15 on my Kenda Unadilla (same tracks).
  • brian389
Posted June 28, 2004 - 01:05 PM
Go with Michelin Starcross hard compound. Plenty of traction (just roll the throttle) and lasts forever. I added 92db end cap, power now, disconnected TPS, and although it feels slower, bike is so smooth, power so linear and easy to ride, I can't bring myself to tune the "hit" back into it. Has significant impact on suspension and handling, as the bike doesn't want to twist on you, and rear does not compress and bounce so much out of the corners. Feels like the motor is electric. My buddy with Honda 450 swears he feels much faster on my Blue Bike.
Good luck.
  • Joe_Jet
Posted July 01, 2004 - 11:23 AM
The MH2 will chunk if you ride it off road. I have been using the MS2 with good results, good traction and good wear.
Joe
  • Ga426owner
Posted July 01, 2004 - 11:28 AM
Starcross MH2 & MS2 are much better than the M12/S12's
  • flogger
Posted July 01, 2004 - 11:30 AM
Maxxis IT. Has held up great for me. Hooks up, durable, cheap. What else could you ask for.
Flog :thumbsup:
  • thriller
Posted July 01, 2004 - 06:00 PM
I second the Kenda Unadilla :thumbsup:
Posted July 01, 2004 - 06:42 PM
Ditto the Maxxis IT. Works in a wide range of soils. Used to shred a Dunlop 739AT 120/100-18 in three good rides on my CR500. Tried a Maxxis and found it lasted 3-4 times as long, and bites better to begin with.
On my 450, it goes about twice as far or more as does a 756.
  • Dolce_Grappa
Posted July 02, 2004 - 01:33 PM
I'll put a third vote on the Maxxis IT rear :thumbsup:
  • Jeffro426
Posted July 02, 2004 - 02:28 PM
Chock another vote up for ITs...great tires, grip just as well as 756s but will last MANY times over...and their cheaper too.
  • DethWshBkr
Posted July 02, 2004 - 04:38 PM
Another vote for a Maxxis IT.
Last long, work great through entire life, and they are dirt cheap!
A Michelin S12 is a soft terrain tire, which also means the compound is stiffer, so there is little flex - the knobs just rip off instead of giving on any harder terrain.
  • hardcore4x4_2000
Posted July 02, 2004 - 07:50 PM
when i first got my bike i put a bridgestone m26 on the rear
..it was gone in a months time but i liked the grip in the mud so i bought another..lasted about a month again..an so on ...6 bridgestone's later i tried the dunlop 739g for thumpers ..lasted all year..racing ,an play'en.. it didn't hook up as well(thats why i have a thumper to catch up an pass later if needed...lol) but for how long it lasted i'll give up a little traction
  • Hamish
Posted July 02, 2004 - 09:46 PM
i just put a maxxis IT on my 426. Seems pretty good so far. I had a VeeRubber on there previously, and it was awesome. Excellent value for money :thumbsup:
