tank capacity...
6 replies to this topic
  • Shane102473
Posted July 15, 2002 - 10:51 AM
I am wanting to get back into some harescrambles. My question is, do you think I need a bigger tank for a two hour race or is my current tank good enough?
  • yznvegas
Posted July 15, 2002 - 11:06 AM
2-hours on a stock tank should just about o.k. It all depends on how much throttle you are using. When I'm riding with my little bro (slow, very slow). I can ride for 2 hours and not even use a 1/2 tank.
The best thing to do would be to go on a 2 hour blast and see where your at fuel wise. I personally wouldn't put a bigger tank on my bike unless I absolutely had too. JMO
  • YZeezee
Posted July 15, 2002 - 11:13 AM
If you're worried about being so close on gas, you may want to try using an additional tank that mounts in place of the front #plate, or something like that. As you ride it'll be the first to drain, so any effect it has on handling will be gone as soon as it runs out-I don't have one, but I believe they run directly into the existing tank-I think Acerbis makes a decent one for around $65. That way you can remove it if it isn't needed at other times...
  • Guest_mxrider426_*
Posted July 15, 2002 - 11:32 AM
I go for four hour rides and have 1/3 of a tank left. How do you guys use so much gas? :)
  • John_Lorenz
Posted July 15, 2002 - 11:44 AM
Its Called WFO
I burn up me Full Tank in 2 hrs easy + - a few minutes
But then again I do have to replace the bubble gum inthat dang crack about every two hrs also :)
[ July 15, 2002: Message edited by: E.G.O.**** ]
  • txthumper
Posted July 15, 2002 - 11:55 AM
i race cross country and cant do a 2 hr race on a tank..i have a 3.2 gallon tank and have less than a half gallon after a race
  • Hick
Posted July 15, 2002 - 12:27 PM
My MPG experience is about 1.5 hours or more for a two gallon tank. Race avg. speed is probably always under 30, but never below 25, and lots of sand washes. I doubt I've ever got an entire hour out of a gallon.
Obviously a tighter race will use much less fuel, but even then I don't think you are going to do much better than one gallon per hour. In short, you may be pushing it...
  • Hot  30 replies
  • 0 replies
  • Hot  28 replies
