34-40 miles then switch to reserve!
23 replies to this topic
  • xrbrp
Posted June 24, 2004 - 05:55 PM
I'm only getting about 34-40 miles out of a tank of fuel. I am doing some hill climbs, 2-3 not many, most of the other miles are on trails with the boys. easy going, little guy on an 80.
I'm asking because I want to do a ride from LA to Las Vegas with a buddy and his friends, but hell, as far as I can get on a tank of gas, I don't think I could carry enough.
any suggestions. This will be my first trip of that kind. my buddy has been doing mexico and I am thinking about that as well,
I hope switching back to the stock sprockets with make a big difference
:thumbsup: :devil: :awww:
  • loufish
Posted June 24, 2004 - 06:46 PM
I have the stock tank, and usually hit reserve at 50 miles. I figure on about 12 miles after that, then I push the bike :thumbsup:
  • qadsan
Posted June 24, 2004 - 06:51 PM
Get a bigger fuel tank or quit twisting your wrist so much :thumbsup:
  • Husky_Forever
Posted June 25, 2004 - 03:16 AM
IMS Products 4.6 gallon tank. Good for about 140 miles in baja. They also make a 7.2 gallon tank for Rallies. Might be your ticket for a long road trip.
  • Roll_it_on
Posted June 25, 2004 - 03:48 AM
The way it would go for me is only a little different. I get 50 to reserve. Most likely 10 to 12 on reserve then push the bike for approx. 1 then life fight to the nearest trama center assuming my buddies bother with CPR on the trail :thumbsup:
  • Pig_N_CR5hundy
Posted June 25, 2004 - 04:23 AM
going back to stock sprockets will help assuming you've gone to like a 14/51 for trail riding. If your going to do a ride to vegas or do a mexico ride, strap on a bigger tank, either a clarke 4.3 or an IMS 4.6 and run 15/48 sprockets. You should get closer to 120 miles out of a tank that way.
  • Old_Man_Time
Posted June 25, 2004 - 04:35 AM
Im running 14 51 sprockets. Im not dual sported but get around 22 miles per gallon in the tight woods and 31 miles per gallon in desert conditions. In the desert I use my IMS 4.6 gallon tank which gives me over a 130 mile range. :thumbsup:
  • yooper_porkchop
Posted June 25, 2004 - 05:29 AM
I have a L with 14/45 sprockets and a Clarke 4.7 have gone as far as 180 and not into reserve yet, but then I don't hammer it either, have gotten as high as 52mpg with it.
  • Seabass
Posted June 25, 2004 - 06:39 PM
34 miles doesn't sound good at all. While racing in the desert I've been getting right around 40 miles before reserve. I just recently put an IMS 3.2 gallon tank. The 4.6 is really big and cumbersome, but so is the XR650!!!!
  • DarrenCalif
Posted June 25, 2004 - 10:12 PM
Thats weird... I have a stock tank and I have yet to hit reserve. I have had rides of 60 miles plus. And still think I have a have a tank left lol I ride the bfp hard too . Wish they had a softer seat.
  • tirebiter
Posted June 26, 2004 - 03:33 AM
Are you still running the stock carb?
Before I switched to a Edelbrock, I'd have to flip to reserve after 35 miles or so. Found the problem to be fuel pouring out the overflow tube whenever the bike wasn't completely vertical. Since the carb swap, no more prob..
You can lower your float height a couple of mm, but that also leans out the low end jetting a tad, back to fiddling with the fuel screw and pilot.
  • heliosstudios
Posted June 29, 2004 - 11:27 AM
Do those with poor gas mileage run a Dynojet jet kit or Keihin jets?
I just received my keihin jets and have yet to install them but in the interim, fuel effeciency (and performance) has been, well, poor. I've filled the tank twice in about 80 miles. We'll see how this changes with the 158/55s.
  • xrbrp
Posted June 29, 2004 - 11:44 AM
I am using the stock carb, and I will be getting a larger tank for the longer trips. thanks for the info guys.
  • Docmarkw
Posted June 29, 2004 - 06:33 PM
You got to be red lining your bike or your jetting is way off. I get about 35 mpg and have a 4.6 tank. I can get anywhere from 150-175 on one tank. Thats riding open desert and jetted at 168 with stock gearing. You might want to check and see if your carb is spitting gas out the overflow tube.
  • BoZerk
Posted June 29, 2004 - 06:54 PM
Yeah, something seems wrong to me.
I'm running uncorked with stock carb & gearing and have gone about 60-70 miles on a tank of gas out in the desert.
I run the clark 4.3 and now no more gas worries.
  • xrbrp
Posted June 29, 2004 - 07:16 PM
I have seen fuel flowing out of my carb tube when stopped and the bike leaning to the side.
  • Old_Man_Time
Posted June 29, 2004 - 07:40 PM
This is a quite common problem. They often come from the factory with the float set too high allowing too much fuel in the bowl. Lower the float 2mm (maybe a little more) and the problem will go away.
  • heliosstudios
Posted July 01, 2004 - 11:47 AM
The mileage with the Dynojet kit has been calculated as follows: in 155 miles, the tank was filled twice (3.6gal), so that comes out to 43.06 MPG. I'm now trying to burn off a tank (read, primary) using the Keihin 158/55s and will post the results in a few days.
  • heliosstudios
Posted July 05, 2004 - 03:34 PM
And the results are in...
XR650L Dynojet 165: 77.5mi/1.81gal = 42.82 MPG
Dynojet overall performance: Marginal
XR650L Keihin 158: 67.1mi/1.83gal = 36.67 MPG
Keihin overall performance: Exceptional
  • flossandfly
Posted July 10, 2012 - 07:17 PM
I have heard reports of 50 mpg from the xr650l. But after instillinig Kehein 55 pilot, 158 main (along with the rest of dave's mods) I get 40 mpg pretty consistently. I have the 14 tooth front sprocket and 45 rear sprocket so may be able to improve highway mileage by reinstalling the 15 tooth front.
I thought there may be a problem but sounds like my mileage is right in line with some other XRL riders. I do weigh about 260 lbs with all gear and backpack on.
  • Hot  186 replies
  • 9 replies
  • Hot  35 replies
  • 17 replies
  • Hot  29 replies
