New Guy - Starting Question
24 replies to this topic
  • JJwinston
Posted July 15, 2002 - 04:44 AM
OK, so I am the new guy and can't seem to find 'the drill' posting that I have heard people talk about. Background - I am a roadracer turned to MX for cross-training and loved it. I was squishing a TTR125L around the track, until yesterday when I picked up my 2000 426. I had started it when I was over looking at it to buy, no problem, first kick. I got out to the playland and had a b*tch of a time getting it going. I was so frustrated and tired by the time I did get it started, I couldn't make enough laps to get the hang of it. I was able to start it with the hot start after killing it on a jump. Any help would be appreciated!! I did read the article on MXA which seemed to be good. I can't wait to try again today.
Thanks!
[ July 15, 2002: Message edited by: JJwinston ]
  • John_Lorenz
Posted July 15, 2002 - 04:54 AM
First Things First
Welcome to TT
I have an 00 also, I did a few mods to it, BK (Best Mod), Blue Wire (Did Nothing).
Outside of that there are a few rules to follow.
<ul type="square"> [*]Make sure the carb is well kept, you may have to pull it apart and clean it, blow air though allits guts.
[*]Air Filter is clean and freashly oiled not to much not alot, The beast will suck in everything[*]check the Valve clearances make sure there in spec
and last [*]Learn the starting drill, live it, love it dream it, and rip the arm off the fool who touches your throttle and beat him sensless with the bloddy end of it
[/list]The throttle should never be touched untill the bike is lit up never never never never and did I mention never...............
I am sure others will have something to add to help you out.
Can you list what is on the bike i.e exhaust, mods if any...Hours of use (estimate)
Oh Ya do you know what jetting is in it stock or ?
[ July 15, 2002: Message edited by: E.G.O.**** ]
  • JJwinston
Posted July 15, 2002 - 05:04 AM
Hey EGO, thanks for the info!! That was about the biggest thing I gathered from the other posts (and when I gave up for the day and decided to read the manual!). I wish I knew all those good questions to ask when I bought it, but didn't. Here is what I know - the guy didn't know how many hours were on it, but said he had just used up the first chain and sprockets on it, and replaced them. The ones that are on there look new. I am assuming stock jetting, as the pipe and everything is stock. He did say he had the fork oil changed at the end of last riding season. What is the BK mod? When I could start it, I had a blast on it! It seemed to have tons of power.
Thanks again!
  • JJwinston
Posted July 15, 2002 - 05:06 AM
Oh yeah, it has Pro Taper bars and triple.
  • John_Lorenz
Posted July 15, 2002 - 05:11 AM
Sound like you have an unknown. If it was my purchase, I would tear into the bike. I would
1: pull carb, clean and validate the jetting.
2: Pull and clean the Airbox and filter /Replace Filter if needed
3: Pull the Valve cover off and chk clearance per manual
4: Replace oil and filter.
5: Go over the engine torq specs i.e. clucth, crank and so on.
Once its done or prior to check the compression of the engine. On second thought check it first before tear down, then check it after its put together.
The bike is a blast once its running and in spec. I have no issues at all starting my 00, 2nd kick cold, 1st kick warm / hot.
The BK is know as the Brian Kinny mod a factory wrench who did this for Tim Ferry's bike.
It reduces the duration of the excelorator pump and makes it adjustable to your liking.
You can find the setup at
http://motoman393.forreal.net look under Tech Articles / BKMod
Good luck
PS what di you give for your 00 just curious
  • JJwinston
Posted July 15, 2002 - 05:22 AM
Great, thanks for all the work you gave me! :)
I do appreciate the helpfull info for the not-so-educated novice. I will post updates as I proceed. By the way, what should I expect for compression?
  • John_Lorenz
Posted July 15, 2002 - 05:31 AM
What ever the Manual says, dont have one handy.
What did you pay for the 00?
  • JJwinston
Posted July 15, 2002 - 05:39 AM
2002 TTR125L (about 15 hours) + 900
Sound OK?
  • John_Lorenz
Posted July 15, 2002 - 05:40 AM
Sorry
What did you pay for the yz426 2000?
  • JJwinston
Posted July 15, 2002 - 05:41 AM
Yeah, that was what I was trying to say, I traded him for my 2002 TTR 125L and gave him $900. He wanted my TTR for his son.
  • John_Lorenz
Posted July 15, 2002 - 05:46 AM
Wow
Sounds like ya ripped the guy off :D that would make your deal worth about 3200 bucks
the 00 by kbb show $4260. Looks like you can spend 1k for fix its :)
Awsome deal, for a RR'r your alright
  • JJwinston
Posted July 15, 2002 - 05:53 AM
Now if I would just retire from the roadracing, I would be able to spend $1K on the thing all the time. Set of race tires for my 2001 GSXR 600 - $375 which is gone by Saturday evening, usually need the second rear by Sunday morning, another $200; entry fees about $200; gas and travel expenses, another $200+. I need a cheaper hobby, and I hope this MX'ing is a little bit! It sure is tougher on the body!
I hope I didn't rip the guy off too bad, it was him that suggested the trade!
  • thumper4life
Posted July 15, 2002 - 06:29 AM
no, you did....you took ego's sandy vasoline and got him good! :)
  • John_Lorenz
Posted July 15, 2002 - 06:34 AM
I call it SandOline
  • JJwinston
Ouch! Well, like I said, he suggested it so I hope he can't come back and ask for more money!! :)
  • John_Lorenz
Posted July 15, 2002 - 06:40 AM
Was this guys name Sledge :)
and was he from...
Ahh never mind
  • JJwinston
Posted July 15, 2002 - 09:10 PM
OK, one last question and then I will let this one go...
I have been doing more research on this starting thing, and found one procedure that seems to have conflicting opinions, so I thought this would be the best place to ask. Do you blip the throttle twice quickly before the first start for the day?
Thanks again from the rookie.
  • John_Lorenz
Posted July 15, 2002 - 09:37 PM
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
If you follow this drill it will start 1st or second kick Hot or Cold, once you have it tuned and the Carb cleaned
http://www.motocross...gtips.asp?id=87
  • JJwinston
Posted July 15, 2002 - 09:43 PM
OK, OK, but even in that article you posted the link to it says this:
Cold start tip: Before you start the YZ-F for the first time, give the throttle two little blips. This will put a small dose of fuel into the top-end. No more than two blips. Never blip the throttle before starting a hot or warm engine.
Does this mean air temp cold, not just the first time for the day?
  • yamie_rider
Posted July 15, 2002 - 09:51 PM
If it has't been started in a long time than you can blip it.
  • 5 replies
  • Hot  38 replies
  • Hot  113 replies
  • On January 15, 2017
