Torque on bolts
21 replies to this topic
  • DJ426
Posted July 12, 2002 - 11:00 AM
With frequent oil changes and constent changing of parts do you all really torque every bolt to spec or do you use your own judgement?
  • sirthumpalot
Posted July 12, 2002 - 11:10 AM
I use the torque wrench. Just because you do something often is no reason to get lazy. :)
  • DJ426
Posted July 12, 2002 - 11:14 AM
Thanks for the reply.
  • John_Lorenz
Posted July 12, 2002 - 11:16 AM
SirThumpy is right
to take a step further get a Trq wrnch that is small and uses inch pounds, The larger foot pound wrench's are better suited for heads, axles and things the smaller more nimble wrenches are more suited for the case bolts...
  • DJ426
Posted July 12, 2002 - 11:19 AM
I am assuming that to convert from foot lbs to inch pounds you just multiply by twelve. right?
  • Hick
Posted July 12, 2002 - 11:40 AM
If I remember correctly that will work.
I have three torque wrenches, but I suppose two is enough. A small one for pinch bolts, cam caps etc and a larger one for axle nuts etc.
As for the importance of the spec, if you notice probably 90% of the time, or more, the spec simply corresponds to the size and grade of the fastener, i.e. I think 4 mm bolts use 10 Nm of torque, i.e. more than that could potentially break the bolt. That would be bad.
So I don't use a torque wrench on seat bolts, levers, oil drain, etc. because I'm fairly confident my bolt-breaking days are behind me. But I think it is foolish to not use a torque wrench on pinch bolts, cam caps, and other engine fasteners (esp. internal) because it isn't worth the risk in those cases.
My two cents.
  • Durtorpedo
Posted July 12, 2002 - 12:30 PM
If I may,
You should definitely use a torque wrench on most everything especially the oil drain on the crank case. It supposed to be 14 foot-pounds. Doesn't seem like much, but tighten it to spec and then next oil change check the torque on the removal, it will take nearly 20 foot-pounds. It has a brass gasket and the way the bolt itself is designed, begs to be rounded off.
  • Guest_mxrider426_*
Posted July 12, 2002 - 02:08 PM
Man, I use a torque wrench on everything. Nothing is worse than stripping an important bolt. And I am pretty shure all of them are important.
  • Jon_Escombe
Posted July 14, 2002 - 11:00 AM
I'd have to confess I hate using a torque wrench on all those little 6mm bolts, very hard to get a feel for it. I think I'm far less likely to strip one with a ring spanner.
The cheesey quality of the Yam fasteners doesn't help either.. Hmm, maybe Ego's right and I just need a smaller wrench!
[ July 14, 2002: Message edited by: Jon Escombe ]
  • Bill
Posted July 14, 2002 - 11:44 AM
Here's a little tip when inserting a bolt into a disimilar metal i.e. triple clamps, linkage and engine cases. Use anti-seize on the bolt thread and even the shoulder. This will allow for more even torqueing and less chance of oxidation, causing the bolt to freeze in place.
Bill
  • EricZ
Posted July 14, 2002 - 12:24 PM
Be careful with lubing a bolt that the manual does not specify lube before torqueing. The reduced friction may actually cause you to overtighten and stretch the threads before the bolt tightens to spec. This includes using locktight on a bolt that doesn't specify for locktight. The bolt is actually much tighter than it feels due to the lube. In short, if the manual specifies a "dry" torque spec, torque it dry!
  • Mark_Cantrell
Posted July 15, 2002 - 04:09 AM
On the CRF450 forum, they've had several bolts with the wrong torque specs leading to stripped bolts. This has led a buddy of mine, normally a sane person, to make up a torque spec and then use a torque wrench to the made-up spec. Sheeesh, Hondas,
Good luck,
mwc
  • John_Lorenz
Posted July 15, 2002 - 04:30 AM
I wanted to wait until I saw some replies.
I have two wrenches on for the cinch bolts 10mm and below. I usually do these in inch pounds. The yz Manual gives both settings.
But honestly what I normally do (I have been wrenching along time)
I use a one handed method with 1/4 inch socketed ratchet. I feel my way by pressure, believe it or not I am pretty much on the money each time.
When it comes to engine work, No doubt torq wrench 100%, axles torq wrench, small mm bolts 10 and below, hand wrench method...
Ok start the flames but you know as well as I the percentage of my method is high
[ July 15, 2002: Message edited by: E.G.O.**** ]
  • Thumpty_Dumpty
Posted July 15, 2002 - 04:34 AM
Sorry guys - I'm gonna be different here. The only bolts I torque on my 426 are the axles, swing arm pivots and triple clamps.
Everything else just gets tightened according to common sense and 'feel' - and I've never stripped a thread or rounded a bolt.
As my dad says.."tight is tight"....
  • John_Lorenz
Posted July 15, 2002 - 04:35 AM
I assume your going by British Standard Right :)
not Metric
  • Thumpty_Dumpty
Posted July 15, 2002 - 05:23 AM
ironically no.... :)
my torque wrench is in Nm and Kgs, but I do use british standard 'tight'....I can see this getting out of hand......
  • John_Lorenz
Posted July 15, 2002 - 05:30 AM
Just goofin Thumpity
  • Thumpty_Dumpty
Posted July 15, 2002 - 05:35 AM
I know :)
  • EricZ
Posted July 15, 2002 - 09:51 PM
Just remember this and you will be fine.
"Half turn past stripped, then back it off a quarter turn."
Just kidding!!
  • Florida_426
Posted July 15, 2002 - 01:47 PM
One long night with a drill and an ezeout from a broken bolt in a harn to get to location and a torque wrench will be purchased :) .
EGO, I think that your wrenching since Archimedes invented the screw has something to do with your finely developed sense of feel :D (thats a joke son.) Please don't ever stop replying to posts. You keep everything in perspective and some large heads deflated :D . Ggod knows I spend too much time with people that take thenselves too seriously iin the engineering and construction fields.
Regards,
Bill Barnard
  • Hot  47 replies
  • On January 15, 2017
  • 0 replies
  • 10 replies
  • Hot  50 replies
