would the 02 426 alum subframe fit a 400 ?
8 replies to this topic
  • rush66
Posted June 23, 2004 - 09:37 AM
wondering if the 02 426 subframe would fit a 400 i know they are different in the tubing and what not but do they mount the same ? and could it be altered to fit ?
  • Satch0922
Posted June 23, 2004 - 11:02 AM
I believe they are interchangable. May want to double check with Yamaha or one of the aftermarket companies before you buy one though.
  • rush66
Posted June 23, 2004 - 12:57 PM
from looking at all the stuff all the mounts appear to be the same but your right i need someone who knows for sure to give the ok
  • Moto-XXX
Posted June 23, 2004 - 01:01 PM
I believe that they are indeed interchangeable.
www.acracing.com
I haven't looked thru their website for these particular bikes so just see if the part numbers are the same.
  • rush66
Posted June 23, 2004 - 01:47 PM
their alum subframe is round tubing and it says it would fit through 2000 but i think the square tubing from the 02 model would still work but i don't know if they change any of the mounting or frame ergos on it in 02 ?
  • Fastest1
Posted June 23, 2004 - 03:13 PM
Is the air box mounting the same? I thought that was the change, but I am not sure.
  • rush66
Posted June 23, 2004 - 03:57 PM
it appears to be the same
  • TimFurryBalls
Posted June 23, 2004 - 07:57 PM
I have a subframe and airbox from an '02 426 for sale if you need. . .
  • rush66
Posted June 24, 2004 - 05:41 PM
another question anyone have any idea how much weight the alum subframe would save over the stock steel ?
  • 10 replies
  • Hot  38 replies
