How much sag?
5 replies to this topic
  • electorn
Posted June 23, 2004 - 08:07 AM
Hi everyone, new here, new 450 and a question already. How much sag should you run on the bike? It has about 6 hours on it at the moment, so I think everything should be settled in. I have set 100mm with me sat on the bike. When I measure the sag with the bike supporting its own weight it only sags about 10mm. Does this mean I should get a heavier spring or is this OK? It seems that I had to wind on quite a bit of preload. Any thoughts?
  • SteadyEddy
Posted June 23, 2004 - 11:27 AM
hey dude welcome,
check out these sites.
http://www.off-road..../tootechp1.html
http://www.off-road....ke/tootech.html
:thumbsup:
  • tcmII
Posted June 23, 2004 - 02:32 PM
Should be just about right. You can also check out the Race Tech (www.racetech.com) or the Tech-Care (www.tech-care.com) for more information.
  • maxtherat
Posted June 23, 2004 - 03:12 PM
You should run a heavier spring. You can get the same sag without running as much preload. Were you in full gear when you did your measurements? If not, then run a heavier spring for sure.
  • RichBaker
Posted June 23, 2004 - 03:49 PM
I'd go to the next step harder, maybe two steps....what do you wheigh?
  • electorn
Posted June 23, 2004 - 07:47 PM
Thanks for your input guys, I weigh 14 stones or 200 pounds in riding gear, and the measurements were taken with me wearing my gear. I haven't ridden the bike since adjusting the sag, I'll see how it feels on the weekend. I think a heavier spring may be the way forward though.
