For those with the White Bros. E-Series exhaust
10 replies to this topic
  • Wrfrk
Posted June 23, 2004 - 04:30 AM
I am curious to know what the average amount of plates are that everyone is using? I've been running 12 on my '00 WR400 but it's so dang loud that I pulled 7 out last night. I did quiet it down a good amount but I am conerned about the loss of power that I may have now. Any thoughts....
  • Vick115
Posted June 23, 2004 - 04:43 AM
im running 10 plates. good power and not to loud
  • yathump
Posted June 23, 2004 - 04:45 AM
You will loss some top end power(not much IMO) but you will gain some in the bottom end. I run normally between 6 to 7 plates on my yz426, i am currently searching for a FMF Q to help quiet it down on the trails.
  • jjk
Posted June 23, 2004 - 06:23 AM
Im running the E-series, so adding plates increases top end, and taking them off adds bottom?
  • Wrfrk
Posted June 23, 2004 - 07:05 AM
That is the "RUMOR" White Bros started, is it true ??? :thumbsup:
  • dmp437
Posted June 23, 2004 - 07:47 AM
Nah, it's true. You enhance the bottom by giving the exhaust a smaller area to exit. Same concept the FMF Powerbomb headersuse; Powerbomb SX (smaller diameter headpipe) boosts the low end, Powerbomb MX (larger diameter headpipe) boosts the top end.
There are also differences in top and bottom power depending on which E-Series you run; ProMeg of S-Bend.
  • Matt96xr6
Posted June 23, 2004 - 08:06 AM
0 - zero
Turndown with a PC t-4 s/a insert.
and it is actually quiet
  • Wrfrk
Posted June 23, 2004 - 09:05 AM
0 - zero
And replacem the whole silencer, I think not. Money tree is dead at my house.....
  • dragon174
Posted June 25, 2004 - 10:22 AM
speaking of the white bros. E-series exhaust... can you buy the screws at any local hardware store or doe they have to be ordered from white bros.?
:thumbsup:
  • holeshot426
Posted June 25, 2004 - 01:06 PM
0 - zero
He is talking about the e-series with just the turndown endcap.
I ran that same setup except I made my own SA, and I lost about half my hp. It was weak. Last time I rode at StoneyFord ranger d!ck made me run 5 disks and my solid endplate and even like that I had to work to loft the front end. It makes best power with 10 disks, no solid end plate and a screen type SA. It does get loud, but I ride mostly private ground where there are no other riders but my bros....
  • dmp437
Posted June 26, 2004 - 12:27 PM
You can get the screws local BUT remember to put "anti-seize" on them when they are installed. There should hav been a little white tube of it included with your silencer when it was new.
