Fork Question
10 replies to this topic
  • SteadyEddy
Posted June 22, 2004 - 12:00 AM
Hi all, Might seem like a funny Question,
I was in the bike shop the other day and seen some air bleed niples for front forks.
Question is:
Why do we need to bleed air from them,
and how often should this be performed?
:thumbsup:
  • Brettv
Posted June 22, 2004 - 12:15 AM
gday, ive always been told to bleed the air out of the forks, something to do with the build up of pressure i think? it can wreck the functioning of the forks....?? not exactly sure, i have heard of people who do it after every ride, i do it every so often, i usually get a little shhhh out and thats all. theres a screw on top of your forks that you slightly undo, the bleeders u saw were they similar to a bike valve??
  • SteadyEddy
Posted June 22, 2004 - 12:21 AM
yer, they srew in to where the exsiting ones are and have the valve on top that you depress, looks very easy to do,
saw them up in sydney on the weekend
  • endurodog
Posted June 22, 2004 - 03:33 AM
Air pressure builds up in the forks on every ride this causes some harshness in the start of the travel of the forks, rougher ride. The going idea is to bleed before every ride. The valves your talking about give you the ablity to bleed your forks at every stop with out breaking out your tools. This should give you a plusher ride all day long.
  • svemo
Posted June 22, 2004 - 04:24 AM
airpressure in forks get higher when temperature raises. Even when you are not riding!
Always let the air out before you ride, otherwise your fork will be stiffer.
  • crf450f
Posted June 22, 2004 - 05:34 AM
the nipples are for rubbing, just kidding, LOL
  • Jekel
Posted June 22, 2004 - 12:02 PM
I have put a set on my bike and it is a great mod. No more dropped little screw in the dirt :thumbsup:
  • RichBaker
Posted June 22, 2004 - 03:06 PM
And, if you want to make the fork temporarily plusher, you can push them in a little and open the bleeder to create a negative pressure in there....works great in a rock garden.
  • vtfootball79
Posted June 22, 2004 - 05:16 PM
I thought the front end had to be off the ground when you bled the forks?
  • RichBaker
Posted June 22, 2004 - 07:07 PM
Normally it does....I said to do this to make the forks even plusher....the negative pressure will help in certain circumstances.
  • SteadyEddy
Posted June 23, 2004 - 01:15 AM
I didn't relise how much you can acctually set up the bike for personal preferences :devil:
Can these things get any better :thumbsup:
