Stock 04 450 jetting
7 replies to this topic
  • Beta_Man
Posted June 21, 2004 - 04:43 PM
A friend of mine just picked up a used canadian 04 yz 450 and the guy he bought it from couldnt find the manual. We put on a full white bros. R series pipe and can not seem to get it to run right. We want to go back to the stock jetting and go from there. We know the guy before had a pipe on it and changed the jetting. So if any of you know what the the jetting is for an 04 yz canadian 450 that would help us out lots, thanks.
  • jetnurse
Posted June 21, 2004 - 05:02 PM
I have the same bike and exhaust. Canadian and WB R4. I have ended up with a 45 pilot, 172 main and clip in 4 position.
Stock is a 42 pilot, 172 main, clip in position 3.
I am in the seattle area, sea level - 400 ft.
I have tried larger pilot and main combo and this seems to work the best with great plug "color"
Hope this helps
jetnurse
  • jetnurse
Hope this helps
jetnurse
  • Beta_Man
Posted June 21, 2004 - 06:16 PM
that helps alot were pretty close then but I think it might have a diffrent needle in it, do you know what the stock needle is :thumbsup:.
  • Vet28
Posted June 22, 2004 - 02:15 AM
I'd have to check my manual, but I thought the Canadian, Australlian & European bikes all camed with 45 pilots and 172 mains? My bike runs best with a 48 pilot & stock 172 main. It ran lean below 1/2 throttle (I do have the Jardine RT4), which requires a little more gas. I haven't found any need to change the clip setting. Get the right jetting, adjust the fuel screw and have fun.
vet28 :thumbsup:
  • GIX1
Posted June 22, 2004 - 04:26 AM
I also have 04 YZ450F with R4 exhaust about 1000ft above I have power now and twin air screenless filter, 45 pilot fuel screw about 1 3/4 out, mj 195, and #4 clip position runs excellent. I know large jet!! never smokes black and nice plug color. :thumbsup:
  • Beta_Man
Posted June 22, 2004 - 05:20 AM
Do you guys know what the stock needle is if i can remeber right i believe it has an OBEMR in it that doesnt seem right. :thumbsup:
  • Beta_Man
Posted June 23, 2004 - 03:41 PM
Do any of you know what the stock needle is for an 04 yz 450.
  • Hot  47 replies
  • 5 replies
  • Hot  36 replies
