Problem with '02 426 5th Gear Surging/Bucking.
5 replies to this topic
  • JYD
Posted June 20, 2004 - 04:34 PM
anyone ever encounter this. when i shift into 5th at pretty much any speed, the bike feels almost like the chain is skipping teeth on the sprocket. the motor isnt misfiring, or sputtering, and it runs flawless all the way to the limiter in every other gear, the second i go to 5th, it freaks out. Could there be a problem with the transmission?
please help
thanks!
  • Matt96xr6
Posted June 20, 2004 - 04:57 PM
sounds like you may have a few missing teeth on the 5th gears in the tranny.
  • JYD
Posted June 21, 2004 - 05:05 AM
is this a common occurrence? im using it for roadracing, and it has VERY tall gearing.
  • John_Lorenz
Posted June 21, 2004 - 05:52 AM
Bent shift fork, broekn gears worn cogs on the gears. If your RR then I would say its time to crack the cases and see whats up, have you seen any metal chunks on the Oild Drain Mag
You do have a Drain plug thats a Magnet dont you :thumbsup:
  • eazrider
Posted June 21, 2004 - 09:08 AM
Arm chair diagnosis:
Worst case,
Shift drum, 1 shift fork, 2 gears, 250$ +300 labor
  • JYD
Posted June 21, 2004 - 09:33 AM
Worst case,
well it does stay in gear at least, just jumps around.
