XRL needle?
2 replies to this topic
  • uw153
Posted June 16, 2004 - 03:07 AM
For those of you who do use the Dynojet needle. I have the clip in the middle position with the washer underneath the clip therefor raising the needle the washer distance. I am also using the 165 D-jet main with a Power Bomb header and FMF Q pipe. The question I have is it runs strong all the way up but puffs out some black smoke on decel. Any suggestions?
  • MotoChris521
Posted June 16, 2004 - 03:40 AM
On decel you throttle is closed so the needle should be bottomed out.Are you sure you have the retainer on properly.Are you sure it's not oil smoke? A 165 main sounds right .I went back to the stock needle shimmed(.040")on mine,i just felt it ran better.
  • uw153
Posted June 16, 2004 - 04:19 AM
Yeah, I have the retainer in good. I forgot it the first time and realized that after I had two screws in the cover already. The only thing I could think of was the fact the the Q uses a reduction insert in the end of the pipe and the smoke was just escaping after some pressure was relieved from the pipe.?? I might just take the shim back out as I don't feel or see any real improvement over just using the needle with the clip in the middle position. I was hoping to pick up some good midrange but that didn't seem to do anything.
Fell Off Trailer by usafxr
  • Hot  43 replies
Honda XR650L 2017
  • 0 reviews
Honda XR650L 2016
  • 0 reviews
  • Hot  60 replies
  • 9 replies
