TE610 FBF 12.5:1 piston
2 replies to this topic
  • huskyfatman
Posted 15 June 2004 - 12:59 PM
Has anyone installed a high compression piston on a 610/570, and if so what were the results. I'm thinking of slaping in a FBF piston and an up-tite cam in my TE610 to haul haul my fat arse up the dunes.
  • Ride
Posted 15 June 2004 - 02:09 PM
Typically high compression = more bottom and less overrev which should work well for a 610.
  • HUSKYTONE
Posted 15 June 2004 - 05:44 PM
I had one in my TE570 for awile. In my opinion, I think it made my lower end fail. too much fatique on the rod bearing and not that much of a noticeable difference. Top end suffered a bit.
Stick with the stock set up-it's a 610, how much power do you need.
