shifting w/out clutch?
14 replies to this topic
  • YZeezee
Posted July 01, 2002 - 07:42 AM
This was posted in the 250 forum, but I wanted to get your opinions on it as well. What harm if any is done by occasional shifting without using the clutch? Primarily downshifting. If it doesn't grind or anything like that, is it a big deal? Thanks.
  • 98yz
Posted July 01, 2002 - 07:48 AM
I downshift regularly without using the clutch, and have done it for years with my 2 strokes as well as my 426. No problems, I just make sure I am off the gas when I do so.
  • John_Lorenz
Posted July 01, 2002 - 07:52 AM
Who Shifts I start in 5th :)
Only time I use the clutch is to start and when I am putzin around, other then that the bike is well suited to handle no clutch shifts
  • YZeezee
Posted July 01, 2002 - 07:57 AM
These things have 5 gears???
  • Hick
Posted July 01, 2002 - 08:06 AM
I heard Ferry's bike is a one speed.
  • YZeezee
Posted July 01, 2002 - 08:13 AM
Maybe it's an automatic. Those factory riders get all the tricks!
  • Sean_McCutcheon
Posted July 02, 2002 - 12:45 AM
I heard Ferry's bike is a three speed.
  • kfrosty
Posted July 02, 2002 - 09:01 PM
YZ, I'm no expert on the matter but from what I've read and watched I believed it's recommended to not use the clutch downshifting so you use the bikes transmission and compression to slow down and control the bike. It was recommended to bump the clutch while upshifting. Think I got that from a Semics video.
  • Vanilla_Gorilla
Posted July 02, 2002 - 04:08 PM
it is perfectly fine to shift without hte cluth s long as youa re off the gas. the biek is made to do so to take advantage of compression braking. BTW, ferry's bike is a 3 speed, with 4th and 5th gearsets made of plastic, they are blocked off by a special shift drum.
-alex
  • westladog
Posted July 02, 2002 - 04:18 PM
"bump the clutch" for up shift? What does that mean?
  • Fireballsocal
Posted July 03, 2002 - 03:50 PM
I also agree that it won't hurt anything to upshift or down shift without the clutch. If your really smooth and blip the throttle as you shift, there is no feeling of shifting gears except of the motor changing RPM. Just a smooth acceleration or de-acceleration.
  • Oregon_Thumper
Posted July 05, 2002 - 05:48 AM
I never use the clutch to shift unless I am going down to first gear, or taking off of course. This is my first dirt bike, but I have been doing it for years on the street.
  • thumper4life
Posted July 05, 2002 - 08:59 AM
rudy on the 250f side clued us in to something i never knew before....the bike will shift when its ready to by you always keeping a steady up pressure on the shift lever, just keep the throttle pinned and have a little bit of steady pressure pushing up on the shift lever, it will shift by itself without you having to take off the the gas. when i read that i was like NO WAY! so i went out and tried it, it works, its pretty cool
i would only recommend this for MX starts off the gate though because it seems like it could easily bend the fork.
  • Victor_Delgadillo
Posted July 05, 2002 - 09:22 PM
clutch? mmmmm
i dont even have the lever.... :)
  • yamaha.dude
Posted July 05, 2002 - 12:02 PM
The only time I use the clutch on a downshift is when I am on tar or cement... then I can use the brakes harder, and I feel that using the clutch to ease the shift also stops the knobs ripping off the back tyre so easily... But then, when I am in my car I blip the throttle on downshifts to match up the revs... that is the kind of driver I am...
When riding on dirt, no clutch... up or down...
Just MHO, YMMV, HTH,
David
  • Hot  47 replies
  • On January 15, 2017
  • Hot  36 replies
  • Hot  28 replies
