426 head on 400 cylinder??
8 replies to this topic
  • 711
Posted June 14, 2004 - 12:12 PM
I got a line on a good deal for a 98 400F, but the head is junk after it dropped a valve. I have access to a 02 426 head, but my question is will it work on the 400 cylinder?
I may get a 420 kit for the 400 since the cylinder needs replating anyway so that would make up most of the difference in the bore size. Thanks!
  • Vanilla_Gorilla
Posted June 14, 2004 - 12:55 PM
I'm pretty sure the only difference is the cylinder bore and the titanium valves. It should work if you do a 420 bore kit. :thumbsup:
  • sirthumpalot
Posted June 14, 2004 - 04:39 PM
Be warned, depending on what came apart and how much it spun after the parts got into the motor, you may need more parts than just the piston, head and cylinder.
  • PumpkinHumper
Posted June 15, 2004 - 01:58 AM
Another option is to check with www.enginedynamics.com They work miracles with heads that you would think are junk. Its worth a call.
  • 711
Posted June 20, 2004 - 09:19 AM
the head is junk....so does anyone know if a 426 head will work on a 400 cylinder??? will be going with a 420 kit.
  • SFO
Posted June 20, 2004 - 03:49 PM
yes
it will work
  • 711
Posted June 20, 2004 - 05:05 PM
Do you know from experience or what?
  • SFO
Posted June 20, 2004 - 05:30 PM
yup
  • rlmeskimen
Posted June 21, 2004 - 04:55 PM
Not to threadjack but if you need a 400 head...I have one from a 99 WR400 if you need one. Give me an email at rlmeskimen@msn.com
Ryan
  • Hot  38 replies
  • Hot  47 replies
  • Hot  50 replies
  • Hot  36 replies
