Stalling Off Idle When Throttle Is Cracked Open
5 replies to this topic
  • JYD
Posted June 13, 2004 - 08:39 AM
my '02 426 stalls occasionally right off idle when i crack the throttle, im assuming there is a problem witht he AC pump either too much fuel, or not enough. doesnt matter if its hot or cold.
  • John_Lorenz
Posted June 13, 2004 - 09:45 AM
When is the last time you cleaned the Carb and air filter?
Is the stalling when the bike is just idling not in gear on the stand in neutral? If yes Totally normal
  • JYD
Posted June 13, 2004 - 11:48 AM
no, it will idle fine, then when i give it gas it dies immediately...but only sometimes......
  • John_Lorenz
Posted June 13, 2004 - 12:04 PM
if your doing this from idle and the bike is in neutral its normal
  • sirthumpalot
Posted June 13, 2004 - 01:51 PM
Did the problem just start, or has it been doing this for some time? If it just started, start by cleaning the carb. What year bike?
  • Jeffro426
Posted June 15, 2004 - 06:17 PM
Clean the carb out well and if it still does it do the BK mod.
