wr450 exhaust dilema
10 replies to this topic
  • J.T.
Posted June 12, 2004 - 07:24 PM
What is the prefered choice of these two options??
I know the cap would save me about $250 . Is it worth the savings or should a guy just go for it and get the "Q". :awww: Or is the "Q" really not worth the extra $$ :thumbsup:
  • JVP
Posted June 12, 2004 - 07:32 PM
I think the PMB works good. The stock muffler on the 04 is pretty good piece of engineering and it relatively light. I have been thinking of drilling out some of the holes in it to get more flow, but I am worried about the noise issue. :thumbsup:
  • J.T.
Posted June 13, 2004 - 05:00 AM
JVP, are you satisfied enough with the PMB the you will keep it or are you searching for better flow ? More power ?
  • WR450F_RDR
Posted June 13, 2004 - 07:09 AM
Big differnce between the two options you suggest, I started with the Pro-moto billet and went to the FMF Powercore IV, I also bought the Quiet core insert for it. In places where you can run the Powercore without the insert you will notice a big differnce but with it, it is about the same, believe me I run without it wherever possible, you cant beat the extra power of the new Powercore IV muffler.
  • mtrablue
Posted June 13, 2004 - 01:24 PM
were you asking about the Q series muffler or powercoreIV with quiet insert? of the 96db mufflers, the Q is one of the better ones. if i had the money to spend, it would be on the Q.
  • J.T.
Posted June 13, 2004 - 04:49 PM
Yes, I was actually refering to the POWERCORE IV Q S/A SILENCER. Not the actual "Q" exhaust. I just noticed that FMF even made a POWERCORE IV2 Q exhaust. I cant find anyone that sells it though.
Posted June 13, 2004 - 08:10 PM
Try www.mxsouth.com , if it isn't listed in the site, call them, they will get it in for you. Good folks.
  • WR450F_RDR
Posted June 14, 2004 - 04:04 AM
you can also try here:
They are out of Eugene,Or
  • ncmountainman
Posted June 14, 2004 - 05:50 AM
i also had the stocker w/pmb insert and the stock jetting was too rich so i drilled through all of those little half holes w/a 1/4" bit helped a bit but more on the top end which is not where i wanted help.so after some research i bought the pwercore 4 w/silent insert and that was much better power delivery,now without the insert the p-core 4 is quite loud(over 100) with it probably right at limit,now they say that w/the pwerbomb header not only is flow increased but it is quieter also! i'm gonna order the header soon. the weight difference is; stock muffler about 9lbs powercore 4 was at aroun 4 !
  • JVP
Posted June 14, 2004 - 06:47 AM
J.T. I like to mess with stuff, so that's why I going to drill out the PMB. :thumbsup: My only concern is noise. I sometimes ride at Hungry Valley and they are strict with the meters. I also have a modified insert from a Raptor that fits in the muffler. I use it for sea level riding in the desert.
  • J.T.
Posted June 15, 2004 - 05:13 PM
:thumbsup: Thanks Guys, I just ordered An FMF powercore IV. I'm going for loud power!!
