Black marks on white plastic?
12 replies to this topic
  • idaho426
Posted June 27, 2002 - 12:19 PM
How do I get the black streaks off of my side panels? I think that they are from my boots. I clean my bike with simple green and it does a hell of a job on everything but that. :)
  • acarter920
Posted June 27, 2002 - 12:35 PM
I have found that a hard-bristled scrub brush with simple green works if you scrub and scrub and scrub... but you can also wet-sand it out. After you wet sand it, spray a quick coat of clear coat on it and it looks like new!
  • Shawn_Mc
Posted June 27, 2002 - 01:13 PM
I use acetone. It comes right off, no work what so ever. Naptha works to and isnt so aggressive.
  • DPW
Posted June 27, 2002 - 02:48 PM
WD-40 works good or a touch of gasoline on a rag.
  • Guest_Guest_*
Posted June 27, 2002 - 02:56 PM
Gasoline.........
Carb cleaner........
Beer..........no never mind that is another story!! :)
  • ejr
Posted June 27, 2002 - 03:10 PM
S.O.S. pad :)
  • Shawn_Mc
Posted June 27, 2002 - 03:11 PM
Where's Ego with that flamethrower??!! :)
  • DPW
Posted June 27, 2002 - 04:16 PM
I wouldn't recommend the flamethrower after the WD-40 or gasoline.
  • motoman393
Posted June 27, 2002 - 04:20 PM
I use fast orange and a brush to keep my sidepanels looking clean.
  • ELECTRICYZ400F
Posted June 27, 2002 - 06:25 PM
I HAVE USED A PRODUCT FOR YEARS CALLED GEL-GLOSS. IT COMES IN EITHER SPRAY OR LIQUID IN QT CAN. ORIGINALLY DESIGNED FOR CLEANING CULTURED MARBLE OR FIBERGLASS. IT REMOVES MOST MARKS WITH LITTLE EFFORT AND DOESNT REDUCE THE SHINE OF FRESH PLASTIC. ITS AVIALABLE AT MOST HARDWARE OR PLUNBING STORES.
  • 696
Posted June 27, 2002 - 08:39 PM
Soft Scrub, keeps the whites pearly white and also has a nice lemon scent!!! :D :)
696
  • PumpkinHumper
Posted June 28, 2002 - 04:47 AM
Im a Soft Scrub /w bleech guy. Works great.
Also Try Mop & Glo once the bike is clean to bring some of the shine back into the plastic. Works great.
  • flyinguitars
Posted June 28, 2002 - 07:57 AM
The wetsanding and clearcoat trick is amazing! acarter920 is right...You can restore plastic back to that new looking, never seen a ride, kind of shine. Ive done this several times on my stock and aftermarket plastic and it works great. Just be careful to clean the plastic with some acetone or some paint-prep type surface cleaner after sanding but before clear coating. I usually do three light coats, letting the part dry and knocking off any high spots or drips or orange peel with some 800 grit paper. Give it a try before you buy new plastic...it takes some time and patience, but it really does work...My riding buddies are all doing now after seeing my bike come back to the track looking new after a plastic gouging/scratching crash the week before. Sorry its a little off the subject, but i figured id chime in...oh yea..a small hand-held electric sander works great.
Mike
  • Hot  38 replies
  • 0 replies
  • 3 replies
  • Hot  30 replies
