PW 80
2 replies to this topic
  • dhowell
Posted June 27, 2002 - 04:22 AM
I realize that this is not the correct forum for this post. But, you guys have always been helpful so I figured I would give it a try. The problem is a PW80 that unless it starts on the first kick (when it is stone cold), it will not start. I usually have to jump/bump start it. It starts no problem with the kick start after the bike is warm. Any suggestions?
Thanks
  • Sparky_So_Cal
Posted June 27, 2002 - 05:50 AM
Are you turning off the gas when done riding it? If you are, then try turning it off and riding it for a few minutes at the end of your day to make sure it is not flooded next time you go out.
Hope this helps,
Sparky
  • sirthumpalot
Posted June 27, 2002 - 05:52 AM
Sparky has a great tip, try his first. If that doesn't work then:
If the carb is clean and in good tune and the reeds look ok (I'm guessing it's got reeds and not a piston or rotary port) then I would take a compression reading. When I hear 2-stroke and must usually push start in the same sentence I immediately start to think low compression.
Did the problem start recently? If so, what changed just before the problem started? If it started a long time ago, has the problem progressively gotten worse?
[ June 27, 2002: Message edited by: sirthumpalot ]
  • Hot  47 replies
  • Hot  38 replies
  • Hot  28 replies
  • Hot  36 replies
