exhaust?
5 replies to this topic
  • jjk
Posted June 08, 2004 - 05:41 PM
I have a 99 WR400, and I was wondering is there a gasket of some sort between the header pipe and the muffler side, where the connection is made with the clamp? The reason I ask is mine leaks at that point. I've tightened the clamp but it still leaks..... :thumbsup:
  • jjk
Posted June 08, 2004 - 05:46 PM
I forgot to mention I have the stock header pipe, with a White Bros E series silencer......
  • WR_Dave
Posted June 09, 2004 - 02:16 AM
Yes there is a gasket. If it leaks you may find alot of backfiring when you get back on the throttle. Although your bike is a 99', TTr's dread backfires. WR Dave. :thumbsup:
  • jjk
Posted June 09, 2004 - 03:33 AM
Will a leak like this rob the bike of power or is it insignificant?
  • holeshot426
Posted June 09, 2004 - 10:39 AM
Match that WB silencer to a WB tapered head pipe and you wont need a gasket plus you'll gain significant low and midrange power...
  • Brettv
Posted June 09, 2004 - 04:46 PM
yeah there is a gasket between the two, its better to replace it or you get a lot of popping on deceleration. i had the same problem on my bike, the yamaha part costs around $20 in OZ
