noisy 426
7 replies to this topic
  • sonnys426
Posted June 08, 2004 - 01:32 PM
Iown a 2000 426 that ive had since new it has reciently developed a knock. It sounds like con rod or piston slap,
I disassembled the top end to do piston and rings, cylinder was still round, the crank and con rod were still well within the tolerance of specs, but when reassembled the noise was still there? I also discovered that when I loosen tension on the timing chain the noise stoped. Timing chain tensioner is working propperly. Any imput would be apprieciated
  • Vanilla_Gorilla
Posted June 08, 2004 - 04:37 PM
are you sure your not tightening the chain tension and that the tensioner is in fact working properly?, if memory serves me right, counter clockwise loosens the chain.
  • 426F
Posted June 09, 2004 - 01:50 AM
Did you check the counter balancer keyway?
  • oldnbold
Posted June 09, 2004 - 05:09 AM
My 00 426 knock came from the counter balancer keyway. do a search and you'll find all kinds of prob's about this on the '00.
  • sonnys426
Posted June 09, 2004 - 02:27 PM
(counter balancer keyway) what exactly should I be looking for?
  • oldnbold
Posted June 10, 2004 - 04:50 AM
slack. the thing should be tight as a drum. The following years Yam went to splines instead of the woodruff key design.
  • sonnys426
Posted June 20, 2004 - 05:31 PM
counter ballance key was the problam, is a new key the only fix?
  • Satch0922
Posted June 21, 2004 - 02:34 PM
Start here
Key fix
  • On January 15, 2017
  • Hot  113 replies
  • Hot  30 replies
  • Hot  47 replies
