Magura Hydr on ´01 YZ426 - Pics anyone???
5 replies to this topic
  • jespertheil
Posted June 07, 2004 - 11:28 AM
I bought a Magura hydralic clutch that hasn´t been used more than once..
Does anyone have a piture of on a YZ426?? I would like to see how it is installed.. I can´t figure out how to mount it on the clutch arm.. Maybe something i missing.. :thumbsup:
  • Fathom
Posted June 07, 2004 - 12:56 PM
There should be a silver peice that goes onto the little do-dad on the end of the cable. I nearly lost mine at the shop when I got the box. The attachment was still in the big box it came in.
  • 4strokeflyer
Posted June 07, 2004 - 02:55 PM
I've got it on mine. The install was pretty easy. PM me and I'll email you some pics if you want. :thumbsup:
  • jespertheil
Posted June 07, 2004 - 09:41 PM
I got the little silver thing that goes on the end, but it looks to small... On the original cable its a small cylinder, but on the Magura its a small round thing..
  • Fathom
Posted June 08, 2004 - 02:58 AM
Right, there is another peice that clips over that peice. It's a cylinder just like in the cable. Your apparently missing yours.
  • R_Little
Posted June 08, 2004 - 03:48 AM
If I recall you have to cut a small piece out of the clutch arm in order to hook the magura slave cyl rod to the YZ clutch arm. I believe the instructions are on Magura's web site in PDF format. Call them Magura.com or MaguraUSA.com or something like that.
Once it is installed you will not believe the difference. I went to YZ timing so I use the clutch a lot now. Without the Magura, I'd switch back to WR timing for sure.
Good luck
