Carb breather hoses: re-routing
1 reply to this topic
  • Andrew_Perry
Posted December 09, 2000 - 07:55 PM
I've found that during deep water crossings the WR splutters and will die if the revs aren't kept high. I she does die, it's an absolute bugger to start until itsbeen left standing for a while (to dry out).
I've been told that re-routing the carb breather hoses to the airbox will solve the problem. I also tested it by putting the hose ends in a glass of water and turning up the idle - it started to suck water up the hoses (I figure water in the carb can't be a good thing :).
I tried putting them all up there but one started to get fuel build up in it - the others seemed OK.
Can someone tell me which hoses should be re-routed and which can/should stay down.
  • Scott_F
Posted December 09, 2000 - 08:37 PM
The trick is to get some small T's at the auto parts store, and route the hoses both up and down.
