devol radiator guards
1 reply to this topic
  • motionmama
Posted June 06, 2004 - 03:16 AM
Probably is easier than it looks but no directions in the bag. Can someone help me with installing my DEvol radiator guards?
  • Indy_WR450
Posted June 06, 2004 - 03:47 AM
Remove the stock plastic deflectors. Take the radiator bolts out (3) and bolt the devols in. You need a real small 1/4" socket set with a real long extension and an 8 mm socket to get the job done. The brace Z- bracket goes on the back side of the radiator. Hopefully the shroud bolts line up with the shroud brackets provided. I had to redrill the mount holes to make it fit right. :thumbsup:
