swingarm bolt
11 replies to this topic
  • Brettv
Posted June 05, 2004 - 01:15 AM
anyone know any tricks to getting the swingarm bolt out? mine seems to be stuck in there nice and tight
or should i just hammer it to death til it comes?
  • Butta
Posted June 05, 2004 - 01:46 AM
If you're talking about the swingarm pivot bolt that goes through the frame and the engine, you have to kind of wiggle the swingarm from the axle side (helps to remove the shock arms, too) so that you can take the wieght off of the pivot bolt. If it is still stuck, you might be looking at a bent bolt, or possibly seized bolt (then a BFH might do the job).... Both of mine came out quite easily once I removed the weight from it.
  • The_Missile
Posted June 07, 2004 - 03:06 AM
Lay your bike down and fill the bolt recess with enough WD40 to create a pool and leave to soak overnight. If its not bent, then it should come out real easy.
  • Fryboy
Posted June 08, 2004 - 09:09 AM
What a great idea ! Thanks for the tip
Fryboy
  • Rich_in_Orlando
Posted June 08, 2004 - 09:42 AM
Use "PB Blaster" instead of WD-40. It's made especially for freeing frozen bolts. I get mine at Discount Auto Parts.
  • The_Missile
Posted June 08, 2004 - 10:28 PM
Fryboy....that trick has saved my a$$ so many times with recalcitrant bolts. First time I used it I built a little dam out of playdo around each of the 6 spark plugs of my 6 cylinder merc (74 280SE with blue vinyl seats....). The garage couldnt pull them during a service :thumbsup:
I sweated a bit myself trying to get them out thinking the garage guy was an idiot :lol:, but they were all well frozen. :awww:
Next morning I pulled all six without even trying.
  • gomopar440
Posted June 09, 2004 - 05:02 AM
I'll second the vote for PB Blaster over the WD-40. Amazing stuff it is :thumbsup: Used it many times on stuff others had counted as stuck solid. It has to be seen to be belived. :awww:
  • R_Little
Posted June 09, 2004 - 07:22 AM
You gotta servise the swingarm bearings every 3 months or it will sieze. I let mine sit over the winter and the bearings were toast in the spring. I'm sure you will find your bearings are toast as well.
Some times these things sieze so bad you have to use a sawzall to cut the swing arm off.
Good luck
  • Brettv
Posted June 09, 2004 - 02:34 PM
hmmm dosnt sound good, ive soaked it in WD40 but havnt tried again, the dude i got my bike off i dont think he has ever greased them so the bearings are probably mashed as.
ill let u know how i go. anyone know if u can get that pb blaster stuff from in oz?
  • Brettv
Posted June 09, 2004 - 04:43 PM
hey got the bolt out this arvo, had to drive it out with the end of a ratchet and rubber mallet, the WD40 trick worked, u could see where it had soaked through into the bolt.
the bearings ae rusted like hell. ah well
cheers - brett :thumbsup:
  • The_Missile
Posted June 09, 2004 - 09:28 PM
glad to be of service.
  • R_Little
Posted June 10, 2004 - 08:34 AM
Get a pivot works kit and some 7/16 (I think) (12MM) bolts 1 inch to 6 inches long and some washers to drive out the old bearings and pull the new ones in.
I just did the job 2 weeks ago.
