can you rev. to high?
8 replies to this topic
  • trunkmonkey55
Posted June 03, 2004 - 06:42 PM
I have a WR450 2004. I was wondering if you can over rev this bike. :thumbsup:
  • RichBaker
Posted June 03, 2004 - 06:46 PM
Nope....it has a rev-limiter built into the cdi.
  • trunkmonkey55
Posted June 03, 2004 - 06:51 PM
sweet thanks that makes my day :thumbsup: :awww:
  • SteadyEddy
Posted June 03, 2004 - 07:50 PM
Is that the same for the 03 model?
  • blue_beast_wins
Posted June 03, 2004 - 10:07 PM
Yes.
  • SteadyEddy
Posted June 03, 2004 - 10:15 PM
sweet, I have been worried that i have been reving to high. but now don't need to worry as much cause i haven't felt it kick in yet.
what sort of RPM's would we be doing when it starts to work :thumbsup:
  • aremean_troy
Posted June 03, 2004 - 10:47 PM
i think for the 250f, the rev limiter kicks in at 13500rpm
for the 400/426/450f, the rev limiter kincks in at 12500rpm
  • Rich_Rohrich
Posted June 04, 2004 - 04:51 AM
The rev limiter on the YZF4xx is set closer to 11,000 rpm , it's a bit lower on the WR models.
Keep in mind this is an electronic rev limiter not a mechanical one. Point being if you downshift under load near the rev limit the force of the rear wheel can mechanically drive the engine well past the normal rev limit. This is a common problem with 125 riders who jump on four-strokes, and is the cause of a lot valve issues.
As long as you use your head these bikes are pretty bulletproof. :thumbsup:
  • Gordingull
Posted June 04, 2004 - 03:50 PM
My manual says 12.500rpms for WR-450 2003
