Wheels same on 250f and 426f?
4 replies to this topic
  • CyPrice
Posted June 17, 2002 - 03:50 PM
Are the wheels interchangable from a 01 yz250f and a 01 yz426f? They look pretty much the same, but wanted to ask the experts to see for sure.
  • Guest_mxrider426_*
Posted June 17, 2002 - 04:26 PM
I think they are the same, except the 250f comes with cheaper D.I.D rims.
  • cfisher185
Posted June 18, 2002 - 03:22 AM
The fronts are the same but the rim is a little wider in the rear on the 426. You can still mount a 250/open class size tire on the 250F rim though ...
  • MANIAC998
Posted June 19, 2002 - 03:03 PM
Yes, I routinely switch complete wheels between the two bikes. Axles, rotors, everything is the same. I never noticed about the 426 rim being wider, hmmmmmmmmmm...........!!! Maniac :)
  • Hootna
Posted June 19, 2002 - 03:28 PM
normally the rear on a 125 size bike is 1.85 wide but a 250 and up would be a 2.15
Wouldnt it work... Yes
I wouldnt try mounting a YZ85 tire on a 250F/426 though :)
  • Hot  79 replies
  • Hot  28 replies
  • Hot  36 replies
Need help by Goforaride
  • Hot  68 replies
