Removing old graphics
7 replies to this topic
  • Guest_Guest_*
Posted May 29, 2001 - 03:53 PM
It's finally time to replace stock '00 WR400 graphics. Any word on the best solvent for removing the glue without melting the plastic underneath?
  • Guest_Guest_*
Posted May 29, 2001 - 04:02 PM
You will probably get 100 different ideas on how to do this, but I always find brake cleaner to take gluey residue off anything espically plastic.
So peel, and wipe!
Darin from Missouri - 1999 WR 400F
Enduro Heaven
  • Guest_Guest_*
Posted May 29, 2001 - 04:48 PM
Try a hair dryer and be careful of the gas fumes. Just a little heat on the surface and peel it off.
  • Tree_Crippler
Posted May 29, 2001 - 07:47 PM
Goo-Gone!!!!!!!!!!
  • Darren_Santilli
Posted May 30, 2001 - 01:26 AM
Electrical contact cleaner
  • Bill
Posted May 30, 2001 - 02:21 AM
Toluene if you can find it. This is what they use in the label manufacturing industry. It can be found at most petro-chem suppliers. Zippo lighter fluid also works great. Try it on a small unseen area first, not sure of it's affect on plastic.
I use a blow drier and peel it off. Then use the adhesive side to pull off any residual adhesive and then use contact cleaner.
The local shop also carries "sticker off", never tried it though.
Bill
97 KDX220, 86 TTR225, 99 WR400f, WR timing, throttle stop trimmed, air box lid removed, White Bros head pipe, silencer and air filter. De-octopussed. Works frame guards and Thumper Rad Guards, Scotts steering damper. Odometer and headlight removed. Cycra Pro-Bend hand and mud guards. YZ stock tank, IMS seat and number plate. Renthal Jimmy Button "highs" and Renthal Soft half waffle grips. AMA, SETRA, Happy Ramblers MXC, Rausch Creek MXC, Tower City Trail Riders.
  • wrpunisher
Posted May 30, 2001 - 07:07 AM
Goo Gone is good. WD40 works in a pinch.
Chris
99WR400F
  • Guest_Guest_*
Posted May 30, 2001 - 07:20 AM
Thanks for the suggestions.
