oil change 02 426
2 replies to this topic
  • macmac
Posted June 16, 2002 - 06:13 AM
I just changed my oil for the first time. After I put in 1.48 quarts of oil I checked my oil and did not get a reading - Any suggestions
  • 426guy
Posted June 16, 2002 - 06:34 AM
check with motor warmed up... very important!!
the first time i changed mine i got the same reading... so i kept filling till i got a reading... big mistake!! over filled it.. after a few laps on the track, i came in and checked level.. well, oil was all the way to top of dip stick!! so warm engine up for a few minutes then check...should be perfect...
good luck
  • Unibomber
Posted June 16, 2002 - 04:28 PM
[QUOTE]Originally posted by Dirt dont Hurt:
[qb]Read the manual. I've made the mistake in the past of just doing what I'm used to, only to find out that things jave changed quite a bit over the years. It's all in the book.
Dude, i was going to drag out this post and go through the whole oil procedure, but reading the manual is the best solution, and really is a must with the 426, if you dont pay attention to some small details it could get expensive.
[ June 16, 2002: Message edited by: Unibomber ]
