Weak Accelerator Pump
2 replies to this topic
  • superdog
Posted June 02, 2004 - 03:38 AM
I have a 2000 WR400. And like a lot of them as it seems, when I whack the throttle open from low rpms, it justs wants to die. I have read many of the post on here about the BK mod and thought orginally that maybe that was my fix, but after looking into the problem, I think my problem is not too much fuel from the accelerator pump but not enough. I removed the subframe and watched as I opened the throttle quickly (engine not running) and noticed that the squirt (more like a dribble) was relatively weak and not very long. So after putting it back together, I started it and manually operated the AP by pushing the linkage down with screwdriver at the same time I opened the throttle and it reved with virtually no bog or stumble. Do the springs in the AP get weak over time? Is there something I can do to fix the AP problem. Any advice would be greatly appreciated.
  • The_Missile
Posted June 02, 2004 - 03:49 AM
you might want to dissasemble the carb and clean. The pump on the older models gets really dirty and sticks if not clean.
  • Wrfrk
Posted June 02, 2004 - 07:12 AM
Please fill us in on the resolution to this issue, I have that same year of WR and I have thought that maybe I need to do the BK mod as well.
