95'XR628 pinging while rpm coming up HELP
I had a slight pinging problem (stock engine, low-mid RPM under load) that I solved by going up one on the pilot (I use a 70 at the lower elevations) and using a cooler spark plug (NGK DPR9EA-9). I always use 91 octane. I don't know much about the 628 kit but I think the compression is signifigantly higher than stock. You may need richer jetting or higher octane fuel. This Japanese guy has some jetting suggestions in the carburetor settings area: XR of XR's - XR 600 specs
If you need some pages out of the factory manual reagarding the kickstarter (broken spring?) shoot me a PM. Welcome to TT. ?:awww:
