Octane Booster For 2004 WR450F
6 replies to this topic
  • NewBee
Posted May 30, 2004 - 12:58 PM
Is a good idea to add an octane booster to my fuel since the highest octane level I can get at the pumps here in Newfoundland is 91.5 or 92 and the bike requires an octane level of 95? :thumbsup:
  • dominator426
Posted May 30, 2004 - 01:12 PM
Your bike requires 95 RON (Research Octane Number) which is equivalent to 91 PON (Pump Octane Number=Research Octane Number+Motor Octane Number/2). Octane boosters and aviation gas can be hard on your engine... My 426 only had a light ping under load in high gears between about 6000 and 7000 RPM on 92 PON, Esso then switched to 91 low sulphur gas. I backed off my ignition timing at the pickup on the stator and switched to a colder CR9EIX plug which helped a bit. I now mix with Sunoco 94 which I picked up about 300 miles away...
  • NewBee
Posted May 30, 2004 - 01:14 PM
Thanks for the info. :thumbsup: :awww:
  • FTD
Posted May 30, 2004 - 01:21 PM
I buy 110 race gas at $4.50 a gallon and mix it half and half with 85 pump for 97.5 octane to help the bike run cooler in the summer and it comes out to $3.33 a gallon or so.
Hoss
  • mtrablue
Posted May 30, 2004 - 05:19 PM
if the bike runs okay and doesn't ping on pump gas, run it. gas does "go bad". so, always use fresh gas if you can.
  • holeshot426
Posted June 01, 2004 - 12:44 PM
Octane booster will eventually gum up your fuel lines and carb. It drops out of solution when you bike sits in between rides. I run 100 unleaded I get for $3.25/gal, bike runs cooler and starts easy.
  • JVP
Posted June 03, 2004 - 06:01 AM
Don't use it! :awww: Buy race gas instead and mix it with premium. :thumbsup:
