has any one put an 02-03 tank on an 01
7 replies to this topic
  • the426master
Posted May 30, 2004 - 06:59 AM
I want to put an 02-03 tank on my 426 because I want the new shrouds I think it will fit but has anyone tried it if so please respond or post a picture :thumbsup:
  • tp3dxf
Posted May 30, 2004 - 07:19 AM
I have a 02 YZ tank for my 01 WR that works fine. I think the tanks and shrouds changed in 03.
  • Satch0922
Posted May 30, 2004 - 07:33 AM
2000-2002 are the same. 03-04 are different.
  • the426master
Posted May 30, 2004 - 08:21 AM
do the 03's mount different :thumbsup:
  • roktoy
Posted May 30, 2004 - 02:55 PM
Can you use the stock '01 WR rad guards on the '00-'02 YZ tank or are the YZ guards different?
  • tp3dxf
Posted May 31, 2004 - 09:43 AM
Stock WR rad guards will work fine on a 00-02 YZ tank. The radiator guards mount to the radiator and have nothing to do with the tank.
  • tp3dxf
Posted May 31, 2004 - 09:47 AM
The 03 tank is a totally different tank. The 02 and earlier models had a 3.3 gallon tank. The 03 and later models came with a smaller 2.6 gallon tank I believe. The shrouds are also different. Remember in 03 the WR went from a 426 to a 450. There were a lot of changes made to the bike.
  • Robert_Brazil
Posted June 01, 2004 - 12:14 AM
I am considering doing the inverse fit an oversized 426 tank on my 450. Can you tell me from you experience if there is now a lot of space under the tank?
The shrouds I buy from the 426, that´s not the problem
