Ego Tribute!
5 replies to this topic
  • DethWshBkr
Posted June 13, 2002 - 03:05 PM
We start out with Ego, in his vulnerable days of TTalk, we all start out as newbies!!
Topic: How to start....the OTHER starting issues!
posted February 20, 2002 11:48 AM
I used to reach over and tap the clown next to me and yell out to him
"Just before the Start I feel like Puking Dont You"
I was never beat to the corner
Topic: White brothers R4 Jetting on 2000
posted February 20, 2002 06:02 AM
I just picked up a 2000 from a nieghbor down the street. It has a white bros R4 Exhaust, Headerand all. I called WB and found that they were (PIN HEADS) did not want to answer any questions.
I am going through the Bike Now doing the break in maint on it. I do not know if Carb has been jetted or not have not got that far. Any suggestions or anyone out ther with a WB r4
Topic: Where is this BK Mod Info for 00 426
posted February 20, 2002 11:56 AM
I have searched the world over
Where can i find the BK MOD
[ February 20, 2002: Message edited
Never Mind I got Admin Pleas edelete this by: EgoAhole ]
[ February 20, 2002: Message edited by: EgoAhole ]
Replied to by "therapture"
posted February 20, 2002 02:04 PM
Some people just refuse to use the tools right in front of them...
Ego lends some helping hands!!!
Topic: R4 exhaust wobble
posted February 22, 2002 05:28 AM
Fixed mine but you need to get ahold of a very good tig welder who knows stainless.
I mad out of stainless steel a small coupler 1 1/2 in long dialinter to slide over the exiting pipe. I know a good wleder who tigged the coupler onto the Muffler/arrester. Just slide it on hose clamp and spings no more rattle
I can send a really crappy drawing if you like
john.lorenz@sylantro.com
When in Doubt
Gas It
Topic: Welding Kick Start Lever
posted March 08, 2002 02:05 PM
Never never wled a part on a bike, I can see it now your out in the desseart and your bike needs to be started you reach for the K.S. and give on good boot, it snaps driving the blunt edge right into you boot and ankle, your bleeding profusly and can not get it to stop, ya pack sand, your shirt a dead rabbit into the gapping hole
Topic: Straightening front forks
posted May 31, 2002 05:51 AM
Agree with thumpy but let me add
if the forks are bent or the crash was serious enough to suggest the tubes are tweaked. Reseting the forks is not the answer. To be safe you should pull the tubes off and take them down to a machine shop and have them measured looked at. A few CM or mm's can cause the forks to bind making for a real harsh ride.
Anyway thats my $4.26 worth Safty First
Topic: No compression problem! HELP!
posted May 28, 2002 06:48 AM
I had the same issue, I found it to be the routing of the decomp cable, seems the guy before me when he replaced the top tripple with a set of applied and protapers, he placed the decomp on the wrong side of the clutch
When the bars were turned to the left the decomp engaged slitly just enough to open it up.
Not sure if thats your case. Though there has been posts with the same problem, dont know the outcome there do a search though may come with something.
Topic: welders
posted March 22, 2002 07:01 AM
For starters: Do you have any experiance in Welding ?
If No
then start with a class at the nearest Vocational center, this will introduce you to some basics in Welding metalergy and fundamentals. Plus it dont look so bad on the resume if you decide to start looking for a job in the field. You will really need to start with MIG and TIG welding arc is an art Mig * Tig will help you with hand control and spacing the beads. Arc is abeast all to its own. Specializing in aluminum and other alloys is a good thing. Once ya learn the basic try and get a job with some older welders and learn from them.
PS: No any of the Home Dumpo, Sears or welder you pay less then 500 bucks for is worth PooPoo
The fun side of the Ego, as we all knew him!!
Topic: Power Now Carb Insert Picture
posted June 02, 2002 07:29 AM
I aint slept with a pig either and I aint gonna try it.
Topic: Tired of bent bars
posted February 22, 2002 01:45 PM
I got tired of bent bars too, So I welded some
Solid Stanless Steel 10/400 direct to the triple clamps, I have done my best to bend em but they hold up now
Topic: strange broken leg
posted March 10, 2002 03:36 PM
I once fell off a bar stool at about 2:15 am. I face slammed the Ground clearing the Table top. I did not break my leg but lost some teeth and my nose is now bent to the left. Cant figure that one out
Topic: ThumperTalk Porno Site Bulk Buy
posted March 21, 2002 03:35 PM
Ya Lets do this
Topic: Couple of neat tricks i've learned
posted March 26, 2002 11:25 AM
My Wife Taught me a new trick
She balances the Key to the Lock of the 426 on my nose.
Then she lets me get it when I give here the ok to buy somethig at the store. I have lasted almost 5 minutes before I give in
Topic: white stuff
posted March 26, 2002 06:42 AM
Dude I think your Bike is Smuggling Coke, Where did you buy the bike ? I hope it was not from the CAli Cartel
HeHa
Ya just gotta laugh if not then the head explodes
Topic: Forearm Pump
posted March 31, 2002 06:38 AM
Hey jdyfletch
forearm pump is caused by a few things:
1: Holding on for dear life (I.E. Handle Bar Grip)
2: Upper Arm Strenght (elbow up)
3: Lower Arm Stringht (elbow down)
4: Susepsion
5: Dehydration
All 4 factors can have termendous effects, Here is what I did to train.
1: Slow down
2: Get a girl friend with Big Hooters
3: Dial the suspension in
4: Drink alot of beer ?
Topic: I think I see a crack
posted April 12, 2002 07:32 AM
With the I think I see a crack Remark
"So said 90lb Chester as he was last seen at the Fat womans nudist colony, just before being sat on"
Ohhhhhhh What a site
Topic: Give this a try!! Very Funny!! (a.ka. PORN STAR NAME)
posted May 08, 2002 11:00 AM
I am part Welch and Part Hungarian
That makes me Wel-Hung
The great one has his vulnerable side......
Topic: List your MX injuries!
posted May 21, 2002 09:12 AM
Ok My turn
1: Torn ligaments in right foot Cast 8 Months
2: Broken Right and Left Feet (Not At same Time) two weeks after I broke the right(Right was stil in Cast)
3: Torn Left Knee, 3 scopes cleaning debree
4: Broken Left Sholder
5: Dislocated Right Shoulder (Had to Place it My Self)Eeeeeeeouch
6: Shatter right wrist 6 hours surgey to rebuild two pins adn three screws(Lodi shirt Track)
7: Broken L5 Vertabrea
8: Blown Disk L5-SI (3 Surguries)
9: 4 Broken Ribs
10: and one really good ball busting tank slapper that made me sing in a high pitch for months...
Ego gets upset!
Topic: Lazy assed engineers
posted June 07, 2002 05:32 PM
Call Ya out after school man
Me and My boys were gonna kick your butt
Ya were gonna rub your nose in the dirt
and make you eat poo-poo
Ya The old fart knows the words, I also have some words that go
I knew I had to rise above it all
Or
Drown in my own SH*&&*T !!!
man thisis gettig to be a bore, Joizey mutt all he wants to do is bone some one doggie style, FreeStyle it aint worth the words to type anymore.
We need to work on C.A.R.B.
Topic: apology
posted May 30, 2002 03:35 PM
Appology excepted
First things first, the personal attacks are true, I placed them in a Quote PM Unquote
I will stand by my positision that I have never attacked first in this PUBLIC Forum.
I challenged this person to find any post of mine that I started the attack, in regards to name calling or out in out hostility.
My posts are sarcastic at best and make fun of nothing more then being the silliness of ones question.
I have never stated in a post (Well Except for the Poor misguided ignorant beep) remark with ShawnMC for which I did step out of bounds.
I can take it as well the sarcasim but not hostil attacks or name calling.
I appologies also to the masses but not to the attacks to yznvegas.
Son let me tell you ignorance is bliss, re-read the starting of the posts, you will find the nature of my PM's to you.
Out side of that I remain the same nothing more nothing less
I will respond no more to yznvegas
truce
That which we didn't believe, but showing that the great EgoAHole is human, and has his faults and concience to help him in this life.
Topic: Egos Best Side
posted May 28, 2002 05:29 PM
Topic: The future of ThumperTalk
posted April 16, 2002 12:05 PM
Shawn I swear you starting to like me
Also, this is a good place for info also a bad place for info, just like any info you need to take with a grain of salt and listen for feedback.
TT is a talk board nothing more nothig less, Some of us "Shawn" take it way to seriuos.
Sometimes we really ned to just step back and see what we are really intending TT to be. Yes WE, We make TT what it is. I agree that the flames should stop (EGO) and the Uncontrolled outbursts also (EGO) so I think I have slowed down quit a bit.
But Its still fun and still informative Even Ducmans MX Socks Question.
Be Safe Be fun and by all means Take a break when it seams to seriuos its only a Talk Board
Topic: Something I must Do
posted June 10, 2002 06:58 AM
Hey all, I normally try to keep things professional here
Nah but this is very close to my heart.
I just want to encourage everyone to help in anyway for cancer research. My mom passed away Dec 21st 1998 from pancreatic cancer, since then I have been somewhat involved in my local chapter and support groups.
This weekend I ran into some old friends of my daughters in San Jose, This little girl age 12 has been fighting Leukemia for a couple of years now. Even Though she is not out of the woods yet, prognosis is good. She is getting treatment at Stanford U, one of the best places to be for Cancer Research.
But here is the issue, treatment is expensive, some families have limited means and Stanford does not turn people away becouse of that. It takes people like you and I to help. Buy donating time, money, clothes, Wigs (Yes Wigs) all this helps with offsetting the cost of treatments and supplies.
Something I would love to do in the future is start a yearly enduro or mx benefit for the local chapter, I dunno.
Well sorry for being smoofy but hey it is another side of the Ego, again any donation to your local chapters is a good thing, Here is a link for additiona info in your areas
http://www.aaci-cancer.org/dlist.htm
I for one, can only hope Ego himself reads this, and decides that we as TTalkers need him as HIMSELF in our online community for bashing,laughter, anger, and good information!
  • thumper4life
Posted June 13, 2002 - 03:19 PM
death wish is an....(long wait) EGO MANIAC!!! :)
:D
  • DethWshBkr
Posted June 13, 2002 - 03:57 PM
I can't help it. I had a few hours of free time! :)
Too bad I wasted them doing that! LOL.
  • thumper4life
Posted June 13, 2002 - 05:22 PM
face it, we know you killed time to wait for the 450
  • Dodger
Posted June 13, 2002 - 05:32 PM
Yup, hour and a half................
Dodger :)
  • John_Lorenz
Posted June 14, 2002 - 09:33 PM
I am touched, I really am :)
You all Like Me!
You Really Really Like Me!
Quote From
The Flying Nun Bimbo Whats her name as she excepted the acadamy award
Actually I thouht it was halrious.. But what brought me back out of me Spritual Walk was the FREAKING WHINNING
4 speed Yuk
I hate yamaha
I know Better 4 speed yuk puke poo-poo
Good to be back ha
  • Hot  113 replies
  • 10 replies
  • 5 replies
  • Hot  50 replies
